HELP selecting stock ls cam replacement for LC9 with vvt, afm deleted
Old Sep 19, 2021 | 01:22 AM
2013AvalancheLC9's Avatar
Originally Posted by RB04Av
LS6 cam would be a DISASTER in a 5.3 truck.
It's not the right thing for a small motor in a heavy (about 6000 lbs: nearly TWICE the weight of the vehicles the LS6 came in) with TERRIBLE gears (remember, not only the gears themselves, but also tire size, go into this).
It would be OK if your 5.3 was going into a Miata or some such. Total mismatch for a truck however.
I doubt you'll even be able to tell any difference between what you have and the LH9. That will most likely turn out to be a waste of time.
One of the 2 choices you get with stock cams: (a) a complete waste of time, or (b) a disaster. Don't make either mistake.
just doing a repair this time around, if i wanted performance the stock cam would be a waste of time. But it should be adequate for the repair
Old Sep 19, 2021 | 06:41 AM
swathdiver's Avatar
5 Year Member
If you change your mind and don't mind deleting VVT, the L33 camshaft is the non-AFM, non-VVT, with the same grind used on the 2007-2009 LC9 engines. It is single pattern camshaft and runs real good.
Silversierra10
Jan 25, 2018 09:00 PM
turboal1
Feb 2, 2011 04:14 PM
CI DENALI
25
Mar 26, 2009 11:21 AM
MNC5
Nov 10, 2007 11:03 AM
eallanboggs
Aug 14, 2007 06:02 AM
