Specific difference between AFM cam and Non AFM cam?
Old Sep 18, 2021 | 04:25 PM
2013AvalancheLC9's Avatar
Default Specific difference between AFM cam and Non AFM cam?
I cant seem to find whats specifically different between a gm afm cam and non afm cam. Like vvt i see has oil holes on the second journal. But afm cams, i dont know, if you had each on your hand could you visually figure out which is which?
Old Sep 18, 2021 | 05:39 PM
68Formula's Avatar
AFM lobes will have different lobe profiles than non-AFM lobes on the same cam. If you install with standard lifters, you'll have an idle instability and misfires due to variation. I don't know if the difference if very visible. You could probably try measuring overall lift with calipers.
Old Sep 19, 2021 | 06:43 AM
swathdiver's Avatar
5 Year Member
What he said! ^^^ The AFM lobes are different and if run with normal lifters will indeed cause misfires as hard-headed folks have found out over the years.
thebrain
May 2, 2021 11:03 AM
griff364
31
Apr 24, 2013 01:44 PM
CAPO
Jan 10, 2010 11:39 AM
86T-Top TA
Nov 12, 2008 07:43 AM
Freakenhye
Oct 26, 2007 12:04 PM
