Help me decide what stall to get for my TQ
I will be running a ATI procharger and I am trying to decide what stall I should use.
2600, 2800, or 3000?
During the summer I pull 4200lb boat with a 1200lb trailer I don't think that a 3000 would pull it out of the water on a steep slick ramp or if it did you would stall at 3000 all the way up the ramp no low end. Am I right or did I miss something?
Help me out guys
Help me out guys
Originally Posted by GirlsDoItRight
your right.. go with the 2600 stall.
You could easily pull a boat up a ramp with a 3000 stall. It may rev to 2700 or so, but what's wrong with that?I'd say go with the 3000 with an ATI.
14 Second Truck Club
The higher the stall, the more heat it will geneate. Even more so when you are pulling a load. It wont affect it on the highway while it is locked up, but when you a pulling from a stop or at low speed it will generate more heat. Even a 2600 will do the same, but the 3000 more so. I dont think you would have a serious problem pulling up the boat ramp too bad, but it would need more throttle to get it moving.
Originally Posted by Black Blown 02
He's not right.
6th vote for the 3000
my dads truck acts real well pullin a 18' bassboat out the ramp
with a tci2600
coulda went alot more on the stall IMO
also it seems like the 3000 would be a better match for the procharger
as a whole
with a tci2600
as a whole
