help installing headers
Old Feb 24, 2013 | 12:03 PM
ou812sm's Avatar
Default help installing headers
I will be installing arh1 7/8 hearder for the first time any tips on how I should do it
Old Feb 24, 2013 | 12:11 PM
GMCtrk's Avatar
Driver side from the bottom. Passenger side installs easiest from the top.
Unhook the steering shaft for easier install.
Old Feb 24, 2013 | 12:46 PM
BIGDADDY1969's Avatar
Cool
Dont what yr make and model but my 08 Sierra in my sig had to remove dipstick and jacked up front high as i could on stands and went in easy with no issues ... ...
Old Feb 24, 2013 | 01:21 PM
AKlowriderZ71's Avatar
11 Second Hall Moniter
If it's a 4x4, remove the front driveshaft to make installing the left header easier.
On the right header, you'll need to remove the dipstick tube, then get the header next to the engine, then get the dipstick tube in place, then install the header. If you install the header first, you'll be taking the header back off to get the dipstick back in.
If you run into difficulty along the way, you can send me a pm.
Old Feb 24, 2013 | 01:30 PM
zachm89's Avatar
i put both sides in from the bottom on my AWD ss, no issues. front shaft stayed in place as well as the steering shaft, passenger side i did remove the dipstick tube but theres no real way around that. The ARH headers fit great, youll love them.
Old Feb 24, 2013 | 02:07 PM
ou812sm's Avatar
Going in to 2009 sierra Denali awd
Old Feb 25, 2013 | 09:11 AM
Vortec350ss's Avatar
I've never done it in a newer body truck, but mine went in with a little force. As people have said, passenger from the top and driver from the bottom. I definitely had to push it past the steering shaft.
Old Feb 25, 2013 | 09:57 AM
03sierraslt's Avatar
If you remove the steering shaft do not spin the steering wheel with the shaft unhooked.
Old Feb 25, 2013 | 11:56 AM
ou812sm's Avatar
Na I will avoid pulling steering shaft is it worth pulling the inner plastic fender
Old Feb 25, 2013 | 02:27 PM
I never have.
zblee
63
Jun 10, 2023 01:25 PM
2500ZL1
Jan 25, 2016 06:30 AM
zblee
Aug 3, 2015 03:45 AM
sauldgold
Jul 23, 2015 02:15 PM
