Help highly modded tahoe wont spin a tire
Old Aug 22, 2021 | 09:44 PM
  #31
Adambrazil's Avatar
Originally Posted by timharber
It might be perfect the way you did it. Just throwing stuff out there. My cam was only .553 and if I recall my guy went with 7.465 pushrods. He spent a ton of time on the preload and the results were a silent valve train.
My build was 11 to 1, 243 heads with Ls6 springs, the BTR stage 2 low lift cam, TBSS intake with flex fuel injectors and a stock gold blade throttle body. You don't really want to spin the tires at all in a AWD but given the right surface it would come unglued and on a wet road it would spin them while rolling.
Tim
if its wet or if I roll into a turn it will get all over the road spinning. But it would do that a little stock. Maybe I was just too optimistic. Only reason I'm not doubting the valve train set up is because my boss help me set it up and I have 0 issues with it. Been in business 40+ years. I just think it would be alot more obvious show stopper problem if it were trying to hold valves open. Runs and drives smooth as the cam will let it be lol. I was really just sure someone was gonna say it's the converter. (My hunch) but I have no supporting info to back it up Great information tho and your build sounds sick!
Old Aug 23, 2021 | 02:33 AM
  #32
3wide's Avatar
Getting the Torque to your tires is just math, even with that low first gear your 4.88 rear end and the 3200 stall should get you moving with out a bog out the hole. Not sure about smoking the tires but there has got to be a problem with your stall and or tune combination preventing this from happening. I talked to someone who has a similar combination but with 4.56 gears and he said he can barely break the tires loose but it can lurch from a dead stop no problem.
Old Aug 23, 2021 | 07:28 AM
  #33
Adambrazil's Avatar
(3200) that wont flash past 2400 and it wont feels like I'm still holding the brake
Old Aug 23, 2021 | 07:54 AM
  #34
Adambrazil's Avatar
Old Jan 17, 2022 | 03:06 PM
  #35
reubone's Avatar
Did this ever improve? Im wondering if it is a tune issue. I would like to take a crack at it
Old Jan 17, 2022 | 09:18 PM
  #36
Adambrazil's Avatar
Default Has not
it has not. I feel it has improved but still won't spin from a dead stop. More than likely a tuning issue as I learn more with HPT the more I realize I do not like the way my truck runs and drives. Now that the weathers cold it's even surging and dieing occasionally
Old Jan 18, 2022 | 07:42 AM
  #37
reubone's Avatar
Would you be willing to let me work on the tune?
Old Jan 18, 2022 | 12:31 PM
  #38
Adambrazil's Avatar
Sure. It may be late when I get to my laptop how can I get it too you
Old Jan 18, 2022 | 12:39 PM
  #39
arthursc2's Avatar
cold start/cold engine surges and stalls may be intake gaskets. Might be worth smoke checking a cold motor or carb cleaner testing a freshly started, yet cold motor
Old Jan 18, 2022 | 03:04 PM
  #40
reubone's Avatar
Send Your stock tune file (if you still have it. If not no big, deal just send your latest) to DA_Racing@outlook.com
Im going to write a basic tune file for you to try out. cam/4.88 gears/3200 stall right?
