Help highly modded tahoe wont spin a tire
Old Aug 8, 2021 | 09:17 AM
Adambrazil's Avatar
Default Be tomorrow... but if it will I'll burn em down and post it
Originally Posted by dantheman1540
Hurry up and go test it, don't forget to video!
be tomorrow... but if it will I'll burn em down an post it!!
Old Aug 10, 2021 | 05:51 PM
silentbravo's Avatar
5 Year Member
Did some tires burn yet?
Old Aug 10, 2021 | 07:09 PM
Adambrazil's Avatar
no it will not. No change
Old Aug 10, 2021 | 07:20 PM
Adambrazil's Avatar
Heres a few pictures not all but some
Old Aug 10, 2021 | 11:20 PM
RedXray's Avatar
100% Redneck
Do a 100 shot of nitrous off the line, that will surely make something happen
Install a line-loc to get the rear brakes out of the equation.
Install a couple windshield washer pumps through the rear wheelhouses for your own portable water box.
If all fails... go with a bigger stall.
Old Aug 11, 2021 | 06:20 AM
dantheman1540's Avatar
Don't need a bigger stall if you neutral drop it
Your truck looks good, looks like a lot of work went into it.
Old Aug 11, 2021 | 07:31 AM
Adambrazil's Avatar
first thing I did after I realized it wouldn't is put the 4:88 gear then a line loc and it's a big disappointment leaks like hell wont loc 100% bleeds past the solenoid. I've seriously given some thought to supercharging it or putting a bit smaller of a cam in it. like a 212/218 and putting the 218/227 in the turbo s10 I'm building. Tahoe still need to be the tow pig
Old Aug 11, 2021 | 08:04 AM
vettelovralexand's Avatar
You certainly aren't being helped by the tires, but there are still things to check. Need to post the log file too. Are you trying to brake torque? Are you stabbing the throttle from a stop? Does it act any differently one way vs the other? What is your air/fuel doing? Does it actually feel like a bog or does it seem more linear like the powerband is just soggy?
Old Aug 11, 2021 | 12:32 PM
Adambrazil's Avatar
I have another log to post but will have to wait till I'm back home. trying to brake tourqe and just stepping from a dead stop wont spin. Also if I'm at a stop not rolling at all it almost feel like in still honding the brake when I take off even past 2600 or so. But from a little bit of a roll like 10-15 It doesn't?? Two different animals from a little roll to dead stop. Also A/F is high 12s low 13s and full throttle. From rolling in on the throttle feel like a bog. from a stop it's like theres isn't much there just loud af until shift. 1st gears horrible
And these tires dont even measure true to size there a little short
Old Aug 12, 2021 | 01:47 PM
tjmath's Avatar
That AFR seems not good. Have you checked through the entire exhaust for any leaks? Could have a major leak and dumping a ton of fuel until higher exhaust speeds?
