Help on header install
Old Apr 5, 2013 | 01:22 PM
chevy1224's Avatar
Default Help on header install
I unwrapped my headers today and found that the flange that mounts to the head is not flat like the stock manifold, instead it has a raised ring around each cylinder port. Do I have the wrong part or are the aftermarket headers just different? I have not tried to fit them yet, wanted to get an opinion first. They are the hooker long tubes, ordered from summit. Application was for 4.8, 5.3 and 6.0. I have the 6.0.
Old Apr 5, 2013 | 03:03 PM
Whitecrewcab's Avatar
That's where the flange was welded to the tube. You can run the thick header gaskets and that helps it seal through them or get it ground flat and use the MLS factory gaskets.
Old Apr 9, 2013 | 02:13 PM
wickedRCSB's Avatar
my hooker LT's are that way..found out the cheap fel pro gaskets from local part stores seal better than the factory style, there thicker
zblee
63
Jun 10, 2023 01:25 PM
Dan Neumann
11
Aug 7, 2022 09:06 AM
2500ZL1
Jan 25, 2016 06:30 AM
mrhino
Aug 7, 2015 10:01 AM
zblee
Aug 3, 2015 03:45 AM
