HELP!!! Damn truck wont stop dieing.
Old Jan 29, 2005 | 12:01 PM
Manic Mechanic's Avatar
I would look for a vacuum leak in the intake system, if you have made sure the IAC is clean and funtional.
Vernon
Old Jan 29, 2005 | 02:30 PM
I guess i'll take the IAC out and clean it. Theres no vacume leak. It idles a nice steady 7-9in vacume.
Old Jan 29, 2005 | 03:39 PM
Flyer's Avatar
Try giving it some mre air in the tuning. Increase the idle air values a little and see if that helps. Also decrease the VE table a little from 400-1200 and see if that helps.
What are the specs on ur cam again?
Old Jan 30, 2005 | 02:37 PM
The cam is 218/229 113 @.560/.560
Old Jan 30, 2005 | 03:28 PM
Flyer's Avatar
Send me your tune and a stock one if you have it.
flyer@woracing.com
Old Jan 31, 2005 | 08:39 AM
marc_w's Avatar
Actually, modifying the idle air tables will throw off the calibration a bit.... that number is the amount of air the computer expects to 'see' pass through the throttle body (and/or IAC) at various idles.... The HPT guys say that you should only modify the idle speeds if you want more air at idle.
Do the 2000 trucks have a throttle follower? Sounds like those values need to be bumped up a bit... (going down with the numbers)
How about the throttle cracker? Mine disabled at the factory. Same things though.
Old Jan 31, 2005 | 10:20 AM
BigKID's Avatar
I am with marc... sounds like you need to tweek the throttle follower table a little. And, yes, 2000 has that table, mine does anyway.
Old Jan 31, 2005 | 01:54 PM
Can you do a screen shot of what it is or just copy and paste what i should do with those tables?
Steve-O-08
Apr 19, 2018 09:32 AM
zo6freak
14
Oct 18, 2015 06:43 PM
wrb002
Aug 31, 2015 12:00 PM
black6spdz
Jul 16, 2015 01:32 AM
rojeho
Jul 12, 2015 06:10 PM
