HELP!!! Damn truck wont stop dieing.
Try giving it some mre air in the tuning. Increase the idle air values a little and see if that helps. Also decrease the VE table a little from 400-1200 and see if that helps.
What are the specs on ur cam again?
Actually, modifying the idle air tables will throw off the calibration a bit.... that number is the amount of air the computer expects to 'see' pass through the throttle body (and/or IAC) at various idles.... The HPT guys say that you should only modify the idle speeds if you want more air at idle.
Do the 2000 trucks have a throttle follower? Sounds like those values need to be bumped up a bit... (going down with the numbers)
How about the throttle cracker? Mine disabled at the factory. Same things though.
Steve-O-08
Apr 19, 2018 09:32 AM
