Help!! Backfire???s
Old Jan 12, 2011 | 01:25 PM
adrenalinep's Avatar
Default Help!! Backfire???s
Posting for my brother. Trucks a 2000 4.8, anyhow we just replaced fuel pump and fuelfilter. Truck is backfiring/popping noise when accelerated hard. What's weird is when I'n neutral or park u can rev it all u want n won't do it. Any ideas Mayb clogged injector. ??
Old Jan 12, 2011 | 01:34 PM
Robert91RS's Avatar
How many miles? Had a tune up recently? Did the problem only appear after the pump change? Any codes?
Old Jan 12, 2011 | 01:50 PM
grey matter 04's Avatar
13 Second Truck Club
Sounds like its leaning out on the topend.
Check fuel pressure while driving to make sure the new pump isnt bad and losing pressure at high rpms
Possible the new pump is weak
Old Jan 12, 2011 | 02:17 PM
145k ,probably due for plugs believe they were changed at 70k.. Truck was running normal before pump when out.
Old Jan 12, 2011 | 02:21 PM
Thanks, will ck pressure later.. It was an aftermarket pump from oreillys.. Which I heard ain't all that great
Old Jan 13, 2011 | 09:35 AM
cams 98 silverado's Avatar
Hey. I'm going to agree with the fact that your new pump may be bad. The pump you got, is it an airtex? Those pumps are cheap for a reason. The pressures it creates are min. For daily use and have a life span of just over a year. Enough to get out of its warranty. If I were you. Go back to oreilly. Buy the delco pump and tell them the airtex isn't working up enough pressure. They have to warranty it. I got my delco pump from napa for 300 pre tax. I also have a school acct. Lol
Old Jan 13, 2011 | 10:32 AM
it was an AirTex
Old Jan 15, 2011 | 07:29 PM
indigoblue's Avatar
might wanna double check that the fuel filter isnt backwards
Lthompson
Sep 15, 2015 07:55 PM
cousblake11
Sep 9, 2015 06:52 PM
WarbirdLS1
Aug 8, 2015 10:53 PM
McAllenSS
Oct 21, 2008 01:09 PM
ColtSteele
Jul 30, 2005 10:09 PM
