Help with Adjusting Timing
Old May 13, 2004 | 03:03 PM
BlownAlaskan's Avatar
Default Help with Adjusting Timing
I Did some logs last night and I am only getting 8deg of advance at launch and then it slowly decays to around 4 deg of advance at the shift point 5600 RPM. How do I raise the timing? My A/F is good at around 12:1, and I am not getting any KR. I have not messed with any of the timing tables at all. What EXACTLY do I adjust and by how big of increments? Thanks for the help.
I have not been able to figure out how to past in a efilive screen shot into one of these posts. How do I do that also?
Old May 13, 2004 | 05:04 PM
Black Blown 02's Avatar
OK, first, what version of edit do you have? Hopefully 1.4.
Old May 13, 2004 | 05:29 PM
I did not back up my later versions on disk so I am stuck with 1.21, till ken sends me 1.4.
Old May 13, 2004 | 05:39 PM
PM me your E-mail address.
Old May 13, 2004 | 06:08 PM
After you install 1.4, This should get you started.
Zero- fuel ratio vs RPM modifier table
Set Knock learn to Max RPM- 7100 Min RPM- 7000 (this will keep you from going into the low octane table).
Multiply IAT vs MAP table by 50%
In the high octane timing table- from .68 g/cyl to 1.2 g/cyl and from 1600 rpm to 6000 rpm(basically a big square area of numbers) set timing to 16 or so. (this should be a safe starting point)
Do these things, then go do some logs and report back.
Old May 13, 2004 | 07:53 PM
hey, where is the iat vs. map table? update turned out fine. ???
Old May 13, 2004 | 07:57 PM
It should be on the same page as the high and low octane tables.
You got the update to work?
Old May 13, 2004 | 08:58 PM
yea, update worked fine. I still can't seem to locate the right table, where is it on the screen? Also, you said multiply the table by 50%, do you mean take all of the values * 1.5, or take all of the values * 0.5?
Old May 13, 2004 | 09:59 PM
OK, sorry. Just looked , and its called IAT vs Load timing.
There is a mult% button in the corner of the screen, and a box next to it. Put 50 in the box and hit the Mult% button. It should cut all values in the table in half.
Old May 14, 2004 | 01:22 AM
ok found it thanks. did some logs and i am getting more timing now, but there is some knockretard in the middle of the rpm range. see pics below:
