Help with Adjusting Timing
Old May 14, 2004 | 10:55 PM
  #21
BlownAlaskan's Avatar
92 octane. That is the best we have here in ak. I usually do log iat's but they are always low here. What makes the knock come in so suddenly like it does in the pic above?
Old May 14, 2004 | 11:30 PM
  #22
Black Blown 02's Avatar
Man, I wish we had 92. We only have 91 here.
That's how knock usually comes on. the sensor hears it, and drops timing immediately.
Old May 14, 2004 | 11:40 PM
  #23
BigTex's Avatar
I agree, you are in the 12.xx A/F range at peak torque. Thats the point cylinder pressures are the highest. Add more fuel in that range. Maybe upper 11:1 range. Then test adding more fuel and more timing and see what results in KR and what feels more powerful.
Old May 15, 2004 | 08:51 AM
  #24
What is the best way to add fuel through edit?
Old May 15, 2004 | 08:59 AM
  #25
Raise the numbers in the PE RPM table.
Old May 15, 2004 | 03:02 PM
  #26
OK. I had to gently lower the timing to 13 in the hugh octane table and now I am getting no knock. I am now trying to dial in my pe-rpm a little closer.
2 questions:
How do you adjust part throttle afr?
when I am cruising and step into the throttle, but not enough to let it shift into 3rd, my advance goes WAY down, any ideas there?
I will get some more screen shots up in a little bit
Old May 15, 2004 | 06:01 PM
  #27
The only thing I've ever changed is afr in PE. I have it set to go into PE at 40 % throttle instead of 90% or whatever it is stock. I don't even know if you can change it at cruise?
Do you have PE delay zeroed? Stock its like 1 second.(not good)
I've never really messed with part throttle timing, so I can't help you out on that.
GXPJAY
Feb 13, 2022 08:15 AM
Gadgetized
Aug 21, 2020 03:14 PM
JordanH
Feb 28, 2017 07:22 PM
03chevytruck
Nov 7, 2016 04:43 PM
Boombastic
Aug 5, 2015 11:38 AM
