help, 1.82 60', 4250stall, bucking bronco! long
Hey parish, do you have autotrac or manual shift? Just wondering, because if yours has held up this long, then mine should hold up too.
single digit dreamer
i have the auto trac. i run it in 4hi though, if i leave it in auto4wd the launch is even more eradic. i had to put some bearings in the front diferential but so far it is holding out.
the front diferential is kind of an odd design, there are nuts(sort of) that locates the bearings, then there are some bend over keepers that keep the nuts in place. i bent that keeper strait somehow and the nut backed off, nor sure why that hapened and i think it may be happening again. i need to get that front end settled down.
