Heads Question
Old Jul 26, 2002 | 11:01 PM
badride's Avatar
Default Heads Question
I've had my truck a few years now. I fhave a lot more knowledge with LS1 engines, I've been seeing a lot of talk about some of the parts interchanging, will the MTI stage 2 heads & cam fit into the 5.3 engine? A better question is will LS1 heads, cam and intakes fit on this engine? Thamnks in advance.... <img border="0" alt="[hail]" title="" src="graemlins/gr_hail.gif" />
Old Jul 27, 2002 | 01:26 AM
oxidizr's Avatar
Moderator / Sponsor
Default Re: Heads Question
The heads and cams are interchangable from 5.3 to 5.7. Stock for stock there are no benefits to be had., but the SII MTIs are a good choice and MTI has an abundance of knowledge to aide you in your cam selection.
As far as the intakes go, they will bolt-up but the truck intake manifold outflows the stock LS1 but not the LS6. The car and truck fuel systems are a bit different as well (cars-static pressure & trucks-vacuum boosting) which makes for some modifications to the rails, lines and injector connectors. It will work but at what cost and what benefit?
Richard
Old Jul 27, 2002 | 02:14 AM
badride's Avatar
Thanks Oxidizer.. So it would be better to put the stage 2 heads and cam package and leave the stock manifold on the truck. Do i need to upgrade the injectors? do you know the flow numbers and what CC's the stock heads are? Thanks for all you help.. I'm trying to get into the numbers your running...
Old Jul 27, 2002 | 03:24 PM
BigTex's Avatar
The injectors you have are rated @ 24.6 #s and will handle up to about 315 NA at the rear wheels before going over 100% useage. Your stock intake will put out more torque than the LS6 - keep it. I hear the intake of the 5.3 and LS1 heads are nearly identical, but the 5.3 has a more restrictive exhause port. Also, the 5.3 has a 1.89" intake valve compared the the 2" from the LS1. The 5.3 has appx 59 cc chamber while the LS1 has about 67 to 69 cc chamber (depends on who you ask). Not sure about true flow numbers on the stock heads.
Richard
Old Jul 28, 2002 | 01:33 AM
badride's Avatar
Thanks BigTex that was very helpful info. sounds like we have a good basis for making the power and tourqe we need.I'm looking for as close to 400 as i can get..
5.3lSilverado
25
Aug 29, 2016 12:48 AM
USMCvet0311
Aug 1, 2015 07:45 AM
bbowerman
Jul 26, 2015 10:57 PM
sauldgold
Jul 23, 2015 02:15 PM
