Heads, Intake, 6.0 swap, Super? What the next step
If you're referring to the 5.3 in your sig, 317's will lower the compression and have a negative effect. WCCH and Texas Speed have some nice head offerings for the 5.3 though. If you plan on sticking with the 5.3, heads would probably be the next step if it were me...then maybe a TBSS intake. Another option is a 6.0 swap, or boost. If you go with a supercharger, I'd get a more boost friendly cam though, and set some dough aside for a possible trans replacement. There's a good possibility that a NA 6.0 or boosted 5.3 will eat your 60E for lunch
What about milling the stock heads?
Where's a good place to pick up a TBSS intake? Found this on ebay http://www.ebay.com/itm/09-11-LS2-Ge...#ht_500wt_1287
Is this a fair price?
I had planned on doing something with the trans especially if I went with boost or a 6.0 swap.
Can't you mill the 317's and get a compression bump?
Where's a good place to pick up a TBSS intake? Found this on ebay 09-11 LS2 Gen III Intake Manifold Assy TrailBlazer SS | eBay
GrooveCityZ71
Aug 31, 2015 12:05 PM
