heads
Old May 15, 2006 | 05:48 PM
blu01slver's Avatar
Default heads
i want to start saving up for heads for my truck... one im not sure how much they run for my 01 silverado 4.8 or if they even make performance heads for my truck... two, can i just buy the heads bolt them on and be done with it... and three should i wait and bore my trck like i want to and then buy them, how many cubic inches will i be at if i bored it 30 over...
thanx
Old May 16, 2006 | 05:36 AM
tdrumm's Avatar
You can get a set of ported stock heads for your truck like I did, or WCCH is about to offer an Edelbrock head made for the small bore 4.8 and 5.3 motors. I will say this though, a head swap is pretty involved. What other mods do you have? I wouldn't do a head swap as my first mod as there are plenty of other things to do that aren't nearly as invasive.
Old May 16, 2006 | 06:37 AM
blu01slver's Avatar
its stock and im kinda a newb to engine performance, and when i herd that new heads would give me like 300hp i was, u kno, reallly happy, but w/e. how involved is it?
Old May 16, 2006 | 07:53 AM
tdrumm's Avatar
There are a lot more ways to get you 300 hp that are easier and cheaper than swapping heads. Since you are new to this, I would start with exhaust and CAI intake upgrades, a tuned PCM, e-fans, and similar bolt on mods. Then if you still aren't satisfied you can look into internal upgrades such as cams, valvetrain, and heads.
You'll find that alot of these mods compliment each other, and that some mods don't deliver big gains unless the supporting mods are done along with them. Take your head swap for example, you can install great flowing heads, but if you are still trying to draw air into the engine with a stock intake and push it out through a stock exhaust system you won't really see the full benefit of the heads because you cannot supply them with enough air or get the exhaust out.
Old May 16, 2006 | 12:19 PM
SS_bnoon_SS's Avatar
Boring 30 over is useless for performance unless your stock pistons/rings are totally shot. For a performance gain, have the block bored to 99mm and get some stock LS1 pistons and you're engine will be a 5.7L!!! Then your head choices are wide open...
Old May 16, 2006 | 01:54 PM
8ALTNG's Avatar
STS
Old May 16, 2006 | 08:25 PM
blu01slver's Avatar
that sounds good but wouldnt tht be pretty close to the max, i heard its not good to go to the max... is that all i would need after boring it to 99mm is just the pistons or anything else.
Old May 17, 2006 | 06:07 AM
tdrumm's Avatar
You would need an entire stock LS1 rotating assembly since the 4.8 has a smaller stroke than the rest of the Gen III engines.
lsxmalibu
Sep 9, 2015 11:08 PM
03regcab sierra
Sep 9, 2015 02:02 PM
axekick
Sep 7, 2015 07:01 PM
sauldgold
Jul 23, 2015 02:15 PM
Aboss
Jul 9, 2015 10:28 AM
