Headlight mod for 2003 Yukon
Old Oct 3, 2003 | 12:20 AM
jhelms's Avatar
Mortgage Banker Mod
Default Headlight mod for 2003 Yukon
Our 2003 Yukon has what seems to be 4 different sets of white front lights.
1) DRL's, below the lows and highs when looking at the truck
2) Lows (9006's, right?)
3) Highs (9005's, right?)
4) Fogs (no idea what rating)
I have a two part question, can I put 9005's in the low beams without absolutely blinding traffic? I've done it before on other cars (just have to modify the base a little bit) and it was perfect.
Also, is there an easy headlight / wiring mod that will let ALL FOUR of these sets stay on when the brights are on? Right now my 'flash to pass' enables the brights with lows briefly, but when you click the stem to full brights the fogs and lows go off.
I'd love to have just a little bit more light on these dark country roads around here...
Old Oct 3, 2003 | 12:27 AM
Banned
Default Re: Headlight mod for 2003 Yukon
the 9005s wont fit in the low beam spot...the opening isn't big enough...or maybe it's the other way around....maybe it's to big....i don't remember but it wont work.
Old Oct 5, 2003 | 02:50 PM
jhelms's Avatar
Mortgage Banker Mod
Some of my other cars ran the same low beam high beam combo as our Yukon. You could install the highs in the low beam location by shaving off a little tab on the light before installing it - I'm guessing it would work the same here??
Old Oct 5, 2003 | 03:41 PM
Yelo's Avatar
Summit and Autozone both sell the kit to turn all 4 headlights on...it is like $19.95 from both places
Old Oct 5, 2003 | 04:08 PM
gonzo 6.2's Avatar
The late models use a different relay,summits are $37 (in that range)
Old Oct 8, 2003 | 09:46 AM
jhelms's Avatar
Mortgage Banker Mod
Just went out and installed 9005's in the low beams and the high beams. There are two very small tabs inside the plug area, just shave those off and they slide right in.
Old Oct 8, 2003 | 06:01 PM
agreif's Avatar
Awesome little write up on the quad beam mod.
http://www.pacific-audio.com/perform...es/239120.html
Along with one that I created when I had some questions.
http://www.pacific-audio.com/perform...es/239370.html
Let me know if you have any ?'s
Andrew
Old Oct 8, 2003 | 11:40 PM
graygmc's Avatar
does anybody know if you have to upgrade your wiring for higher wattage bulbs. i know they sell a kit for it but is it necessary?
Old Oct 9, 2003 | 01:49 PM
MonteCarlo31's Avatar
Gray,
I hear from some diesel guys that the new wiring kits work great. www.kennedydiesel.com sells them, very high quality product.
murderedSS
27
Oct 12, 2015 11:13 AM
Justin87gn
Sep 10, 2015 12:06 PM
bisqikss
Sep 8, 2015 03:35 AM
the owl
Sep 4, 2015 04:09 PM
God Made Chevy
Sep 4, 2015 12:29 AM
