Headers, heat, and tranny problems??
Old Apr 26, 2006 | 11:56 PM
dbs1's Avatar
Default Headers, heat, and tranny problems??
I noticed that since installing long tube headers on my truck, it began the issues with a hot running tranny, and it just got worse with the turbo setup (see classifieds for turbo/engine sell).
I am going to go back to the n/a route when the turbo sells, and probably going to go back to a shorty or mid length header similar to some jba's I ran when the truck was new and did not have the tranny heat issues.
I'm looking for suggestions on what headers will give the most gains in the mid length style, least amount of issues with leaks and rust, and bolt up without gyrations. Thx!
Old Apr 27, 2006 | 10:24 PM
you could always spend 50 bucks on a tranny cooler
Old Apr 27, 2006 | 10:26 PM
99Silver6.0's Avatar
Hamm and LaPole headers kicked ***. Check yours and make sure you dont have a tranny line right against the header.
Old Apr 28, 2006 | 01:19 AM
dbs1's Avatar
Ok, young mr smart ace, er I mean drooled or spooled or whatever-I have 3 tranny coolers on it now.
The tranny lines have been bent as far away as we can get from the exhaust, without relocating them completely, which may be the next move, and everything is wrapped with heat wrap, and the exhaust coated.
That's why I asked about the shorty-midlength headers, as they seem to not create the heat issue that full length headers do.
Old Apr 29, 2006 | 12:50 AM
hey man iwas just trying to help with throwing oout suggestions, i didnt know you have 3 coolers, i dont know much about headers so i wasnt going to touch on the subject other than if you change them i'd be willing to buy your old ones if you have a 5.3l with longtubes that arents to used
Old Apr 30, 2006 | 12:01 PM
dbs1's Avatar
Old asm lt were sold last year. Current exhaust is custom made for the turbo setup.
Old Apr 30, 2006 | 12:09 PM
Quik's Avatar
5 year bitches!
3 coolers why not just get one good one. something isnt right you need 3 coolers honestly.
i run mids and no issues with heat what so ever just had to tweak the lines some to get around the starter and not interfer with the headers
Old Apr 30, 2006 | 02:33 PM
3 coolers???? How small are they?
Old Apr 30, 2006 | 02:47 PM
parish8's Avatar
single digit dreamer
headers or a turbo wont cause your tranny to run warm. my tranny lines were less than 1" from my cross over tube and i only get over 200deg's if i hotlap the truck at the track. i have a $50 cooler and a 2800stall.
what is your set up? how are you monitoring the tranny temp? is the coolant temp hot too? do you have a big front mount intercooler right in front of those tranny coolers? just looking for other causes...
pittman
Jan 19, 2016 07:06 AM
greedygenius
Sep 3, 2015 06:51 AM
Chiphead
Jul 13, 2015 10:16 PM
Suburban2500
Jul 13, 2015 09:57 AM
