Header/manifold bolts
Old Feb 5, 2012 | 07:10 AM
DTHPROOF's Avatar
Default Header/manifold bolts
Hey guys, my 2001 Silverado is about to get a set of Cal-speed lt's installed when they get here. I've had a lot of people tell me that the stock exhaust bolts are probably going to break taking them off. Anybody know a technique to prevent this? I plan on soaking them with PB Blaster over night at least.
Old Feb 5, 2012 | 07:54 AM
AndysC3's Avatar
Soak the bolts in some PB blaster the day before and when you start to take them out. Take it slow and try not to force it too much. I would recommend getting some new bolts or better yet some studs. I used these
LS1 HEADER EXHAUST STUD KIT- S/S | eBay
Had em on for the past 8000 miles with no issues.
Old Feb 5, 2012 | 09:21 AM
DTHPROOF's Avatar
Thanks man! Will do.
Old Feb 5, 2012 | 09:41 AM
4.8whipple's Avatar
i was told the same thing. friday night we put LTs on my 99 4.8 and on a friends 03 5.3 and we both had no problems i will say this, we had to take the little heat shields off the fire wall. just a heads up. best of luck to you and enjoy the the headers !!!
Old Feb 5, 2012 | 02:35 PM
DTHPROOF's Avatar
Thanks for the encouraging words friend!
Old Feb 5, 2012 | 02:42 PM
SloStepSide's Avatar
I started soaking my bolts the day I ordered my lt's. Not the first problem. Like said just go slow. Also I reused my bolts and gaskets, haven't had a problem yet.
Old Feb 5, 2012 | 03:01 PM
whitedakota's Avatar
What's wrong with the bolts that come with the cal speed long tubes?
Old Feb 5, 2012 | 04:50 PM
neilownz's Avatar
There are gm stud/bolt part numbers too. They come in different quantities than a full 12 kit.
Old Feb 5, 2012 | 05:05 PM
726.0chevelle's Avatar
13 Second Truck Club
when I did my motor swap 1 header bolt broke and 2 more were already broken. The lq4 had 2 bolts broke 1 i heated up with a mapp gas torch and was able to grab with some pliars the other i had to drill out. I would be scared to do a header swap on a high mileage truck. I swapped to all grade 8 bolts and plenty of antisieze
Old Feb 5, 2012 | 05:15 PM
Mangled03gmc's Avatar
Baltimore Whore
Like said, soak them with some good penetrating oil. Next that has worked for me in the past, is to let the truck run a few min's prior to trying to take them out.
