Header/manifold bolts
Hey guys, my 2001 Silverado is about to get a set of Cal-speed lt's installed when they get here. I've had a lot of people tell me that the stock exhaust bolts are probably going to break taking them off. Anybody know a technique to prevent this? I plan on soaking them with PB Blaster over night at least.
Soak the bolts in some PB blaster the day before and when you start to take them out. Take it slow and try not to force it too much. I would recommend getting some new bolts or better yet some studs. I used these
LS1 HEADER EXHAUST STUD KIT- S/S | eBay
Had em on for the past 8000 miles with no issues.
i was told the same thing. friday night we put LTs on my 99 4.8 and on a friends 03 5.3 and we both had no problems
i will say this, we had to take the little heat shields off the fire wall. just a heads up. best of luck to you and enjoy the the headers !!!
when I did my motor swap 1 header bolt broke and 2 more were already broken. The lq4 had 2 bolts broke 1 i heated up with a mapp gas torch and was able to grab with some pliars the other i had to drill out. I would be scared to do a header swap on a high mileage truck. I swapped to all grade 8 bolts and plenty of antisieze
