header install ???'s
Reuse your factory gasket. I did on mine it came apart into 3 pieces but when you put the bolts through it and tighten the header down its fine and no leaks. I ahve take teh header/manifold off 3 times and reused the same gasket all three times and it has 168,000 miles on it. I reused the factory botls too and no problems with that either.
Originally Posted by CHEVY6000VHO
Here is the Stage 8 locking header bolts part # for our trucks: 8900
Comes with 12 of them. They are priced at $49.90 at www.stage8.com web-site.
Hope this helps.
Jim
Hope this helps.
Jim
how much do i torque them down? and how much is a torque wrench. got a garage full of craftsman, dewalt and snap-on but no torque wrench
11 ft lbs 1st pass ,then 18 ft lbs on final pass. That means......not a whole lot! Aluminum.....Aluminum.....Aluminum!!!!
Jim
Originally Posted by 99Silver5.3
Those Stage 8's are a nightmare. Id say about 30 minutes after you fart around with the first lock, youll be throwing the rest across your garage!!!!
Jim
If you want some good locking bolts that aren't a pain to install, get these:
http://www.go-breslin.com
I've got them on my Av and they're a great product. They aren't cheap but sometimes you get what you pay for.
zblee
63
Jun 10, 2023 01:25 PM
zblee
Aug 3, 2015 03:45 AM
