header install help
Old Nov 9, 2010 | 08:59 AM
low_life96's Avatar
Default header install help
i have some pasetter longtubes with no flanges on them just a smooth end... what the best way to have them attched to the the rest of my exaust just cut an weld a pice back in or do they make a pipe the will bolt in were the factory y pipe dose??????
Old Nov 9, 2010 | 09:14 AM
TX Tahoe Z71's Avatar
You need the pacesetter Y pipe, the LT's were not intended to bolt up to your stock Y, if I am understanding you correctly. But to connect the headers to the pacesetter Y, you will want to use a lap joint band clamp, available at NAPA for around $13. They look like this:
EDIT: Also throw some copper RTV in there for leak protection!
Old Nov 9, 2010 | 09:26 AM
low_life96's Avatar
most guys i kno just cut the factory y down an weld it the the lt..... im just seeing witch was is better an cheeper.......... any websites that i can find the pasetter y pipe?
Old Nov 9, 2010 | 09:29 AM
low_life96's Avatar
is this wat your talking about? http://texas-speed.com/shop/item.asp...d=840&catid=45
Old Nov 9, 2010 | 09:45 AM
Originally Posted by low_life96
Yep, that's what you need. I have not heard of many people cutting their stock Y and welding it, seems like a bad idea if you ever needed to pull the headers off to drop the trans or something like that, not to mention you have these 3" collectors going to a 2 1/4", or whatever stock is, Y pipe. If you need the cats to pass emissions though, that might be a quick and easy solution. Just my $.02.
Old Nov 9, 2010 | 09:59 AM
low_life96's Avatar
ok thanks........ emissions i live in oklahoma i dont thank there such around here lol........ wonder if anyone on here has an used or new one they want to sell???
Old Nov 9, 2010 | 11:14 AM
axekick's Avatar
A used or new what?
Old Nov 9, 2010 | 11:27 AM
Originally Posted by axekick
A used or new what?
From above:
Originally Posted by TX Tahoe Z71
You need the pacesetter Y pipe...
Old Nov 14, 2010 | 08:07 AM
low_life96's Avatar
Are yal using the paper type gasket that comes with the headers???
Old Nov 15, 2010 | 07:40 AM
14psisupra's Avatar
stock gaskets on mine
