Header flange broken!
Old Mar 13, 2019 | 04:42 AM
  #21
Northeastconfederate's Avatar
5 Year Member
Originally Posted by wretched73
I'm not really sure what you're asking? What do you mean the weld disappeared?
Poor description on my part. Where it broke at the union between the collector and the pipe flange. The weld had obviously been ground and polished; and there wasn't a lot of filler material there to begin with. What was left when the flange came off the collector was just a thin ridge where it had been welded. It looked like it had corroded away, maybe. Or possibly the flange material corroded out from under where it had been welded.
what I've seen in the past in different applications is the tubing right next to the weld would break, but the weld would be intact. In this case, nothing broke, per se. The pipe pulled out of the flange. Like the weld didn't "stick" to the flange. Yet, it had been joined there just fine to begin with.
Old Mar 13, 2019 | 06:53 AM
  #22
wretched73's Avatar
I'd guess there wasn't enough penetration when it was welded. Mild steel to SS shouldn't have any issues as long as the right filler was used.
Old Mar 13, 2019 | 01:20 PM
  #23
1FastBrick's Avatar
Custm2500's Rude Friend
Basically what he said.
They use very little filler. Its almost a fusion weld where the 2 base metals are heated just enough to get them to melt together. They use little to no filler rod to keep it molten and the 2 base metals flowing. It creates a very flat weld but is very weak
Old Mar 17, 2019 | 10:34 AM
  #24
5 Year Member
Thanks for the explanation, fellas.
1BadAction
Mar 15, 2006 08:30 PM
bigredexpress99
May 18, 2005 06:56 PM
creederado
Jun 27, 2004 07:34 PM
70 TA
13
May 28, 2004 11:54 PM
ArticGMC
Jun 28, 2003 04:09 AM
