Header install and flange question
I'm looking to get a set of mid tube or long tube headers. If I install them myself what am I looking at to get the flanges rewelded? On shop said $250 which I think is a little high.
The other question is does everyone just tie up the rest of the exhaust and drive to their shop to get the flanges fitted?
This is on a 5.3 sierra.
Thanks,
Lar
Thanks,
Lar
Re: Header install and flange question
My friend just removed his y-pipe out of his truck, then drove it to the muffler shop. It sounded crazy loud, and his check engine light came on for the 02 sensors missing, but after he had the y-pipe fitted and reinstalled, he just used the predator to erase his code!
I paid $100 plus $20 lunch plus stock manifold and I had to do most of the work myself. It took about 2 hours. We ended up cutting the pipe right on the stock welds for the cats and it still barely worked. The crossover pipe has now mover back right beside the crossmember and it was banging where it went over so we heated it and knocked a tiny dent so it wouldn't rattle. We also had to shorten the catback system about 3 inches because of this. Also the top bolts were a bitch but I think it was because the truck was lifted too much. I have another question. How do you weld the flanged to the cats? From the outside or the inside? We did mine from the inside and grinded it down smooth. I thought it was supposed to be done from the outside, but then how would you get the bolts to go in flat? Thanks a lot, lets get all the good info in this thread for future reference.
The ASM headers, had about 3 inches to cut off of the y-pipe, and they including new flanges that would be welded onto the y-pipe, there was about 1 inch of pipe left coming off of the cat to work with. I have not seen any others be installed.
zblee
08-03-2015 03:45 AM
sauldgold
07-23-2015 02:15 PM
FlowmasterMufflers
07-17-2015 03:26 PM
