Header bolts?
Old Mar 5, 2013 | 11:24 AM
Slammed silverado's Avatar
Default Header bolts?
In a couple weeks I'm installing Texas speed stainless long tubes on my 2000 silverado 5.3 and was wondering what header bolts to use? Could I use some from acdelco or something like that? It's a Midwest truck and I don't think ill be able to reuse they are pretty rusty and I wanna use something kinda nice as well, but let me kno what you guys think and thanks for the help!
Old Mar 5, 2013 | 02:07 PM
asap216's Avatar
It doesn't come with header bolts? I know a few people running stage 8 locking header bolts and no complaints. Just becareful taking the old ones off.. They like to break.
Old Mar 5, 2013 | 02:18 PM
dmelvin's Avatar
You can get a set from Summit as well.
Old Mar 5, 2013 | 02:24 PM
No they didn't come with any that I could find, I looked in every box and I didn't see any bolts and I will check out summit
Old Mar 5, 2013 | 02:27 PM
What size are those bolts that are on the manifolds?
Old Mar 5, 2013 | 03:04 PM
chevyboy.520's Avatar
eBay has header studs. I'm running them with my turbo manifold
Old Mar 5, 2013 | 04:08 PM
nonnieselman's Avatar
M8 x 1.25, maximum drill depth is 16mm so add the thickness of your flange and that should give you an idea of how long the bolt needs to be..
http://www.enginepartsplus.com/pdf/P...%20Catalog.pdf
http://www.pleasurecraft.com/manuals/L510016.pdf
Old Mar 5, 2013 | 04:18 PM
Sweet!!! You guys rock this helps a lot, if anyone has more info have at it!!
Old Mar 5, 2013 | 06:22 PM
MB2008LTZ's Avatar
I just ordered some Stainless ARP Header bolts from Summit Racing...$60. Going to use them with my ARH header install hopefully this weekend, if they get here by then.
Old Mar 5, 2013 | 06:40 PM
2000SSilver's Avatar
Check out Percy's split lock bolts. Used them several times. Look great and wont back out.
