head porting suggestion
Old 11-25-2014, 09:10 PM
qwkvert's Avatar
But what does the converter have to do with 50 to say 100? The truck never drops below 4k the whole time?
Please educate me?
Old 11-25-2014, 09:19 PM
qwkvert's Avatar
Originally Posted by Sales4@Texas-Speed
Agreed. That cam needs more converter. I would recommend at least a 3000 Stall. Give us a call and we can get you into a good converter for $400.
Btw, I was told by numerous people that your 228 cam was going to be way too much, and I would lose my bottom end if I did it, but were they wrong! I want more cam now.
I think most of my problem was in the tune, and my restricted exhaust. Tune is better today, and ride the truck sideways to about 60mph tonite..lol. I want going into pe mode and was running too lean.
Need to get some better heads too... it never ends...
Old 11-26-2014, 07:38 AM
Truckshop's Avatar
Please educate me?
Read up on convertor efficiency. That'll answer most of your questions. My recommendation is yank.
Old 11-26-2014, 11:42 AM
qwkvert's Avatar
So is the implication here, that my tb converter is probably slipping too much to accelerate under the heavy load by the higher speed?
Old 11-26-2014, 12:40 PM
gamble686's Avatar
Unless you are locking the converter then yes you may notice some slipping. I would guess that being an autozone stall it's not the very best quality and naturally its not overly efficient. If I remember correctly converter efficiency was a huge factor for blown06. In high powered setups it becomes increasingly more important. Think about it this way you wouldn't use a stock clutch built for 250hp 3000lbs car in a 600hp 5000lbs build. So why would you use a stall built for a 150hp trailblazer in a 400+hp full size. Swapping to a proper stall built for your setup will help dramatically.
Old 11-26-2014, 12:45 PM
qwkvert's Avatar
:-) cause I was a cheap ***
greedygenius
09-03-2015 06:51 AM
GrooveCityZ71
08-31-2015 12:05 PM
JordanH
08-08-2015 07:59 PM
bbowerman
07-26-2015 10:57 PM
jmarkway
07-18-2015 09:23 PM
Quick Reply: head porting suggestion
