head bolt torque numbers
Not to mention ... the studs are kinda dummy proof. You just drop the head in place and it's there. There are different torque specs for the studs though. I went by what's on ls1howto rather than the instructions.
th ebiggest thing with either the studs or bolts is make sure the holes are cleaned out.
Banned
definatly...as soon as i pulled the stock heads i started blowing out the bolt holes and putting paper towels in them....gotta grind down a bolt and clean the threads and i'll go from there. you don't have a pic of your studs with the heads off do ya? thanks for the info Flyer, you gonna make it to the SBSO?
No pictures ..
Unfortunantly I can't. I am going down to San Antonio the weekend after the shootout. I am going to have to stay for about 3 nights as well. I can't afford the 6 hour drive down there and to stay a night and urn around and do it again.
As much as I want to make it .... I just can't.
Banned
well, i ordered some 12pt studs today....damn my wallet is hurting after that. ordered a set of ARP header studs and some other parts to get it back together
Banned
the 6pt is $17 cheaper, but teh 12pt offers a larger nut surface coverage area (not a big difference.) not sure how much bigger but every little bit helps. plus the hex head studs are on national back order but the 12pts thunder had a couple sets so i did that.
signguy62
07-27-2015 03:42 PM
