H2 Radix Dragstrip Results
Old Feb 22, 2005 | 04:08 PM
  #31
Mort's Avatar
Great vid, congrats on the results. The H2 sure pulled off the line nice. No fuss, no muss just up and went.
Old Feb 22, 2005 | 06:01 PM
  #32
CHarris's Avatar
We're starting to wonder if a trailblazer heavy duty convertor might let it see a 1.9x 60 ft. As it is, a 1500 rpm foot brake yielded a 2.19. I could probably foot brake a little bit higher still. I do like the way it leaves right now. Anyone could drive this thing.
Old Feb 22, 2005 | 06:18 PM
  #33
moregrip's Avatar
what a rush!
just for comparison sake, the best 60ft I can manage without brake stall, is 2.2. With brake stall I just light'em up!
Old Feb 22, 2005 | 06:51 PM
  #34
Mort's Avatar
If you have the same stall as in our 4L80E you should be able to stall to 2500 no problem. If you still have traction you will move right out. If I stall to 2500, which I do , I will get a 2.7 60' and spin the tires some and if I launch in 4X4 I will get a 2.4 60' and just a chirp. I see that the H2 has a 4L65E so I have no idea of what it will stall to so theTB stall might help for sure. You might even want to consider a higher stall than that.
Old Feb 22, 2005 | 06:53 PM
  #35
CHarris's Avatar
I wish I could 4-wheel scale the H2. I think the balance is pretty damn good. As a matter of fact, with no spare tire the rear tires don't bulge at all. The fronts do some and it seemed a little more prominent with the Radix install. Anyway, I just run the tires at the recommended 37 psi and drive away.
Old Feb 23, 2005 | 08:53 PM
  #36
tbyrne's Avatar
Nice ET! I'm thinking about getting one to lift later this year. The Radix will be the power adder that I go with. The H2 needs more power so this supercharger is a good way to give it a boost
ORDER LINE - 1-877-4-TBYRNE
SEND US E-MAIL
WEEKLY SPECIALS CAN BE SEEN ON OUR WEBSITE
Old Feb 23, 2005 | 11:40 PM
  #37
CHarris's Avatar
I'll bet a great deal of my decent 60 ft time is attributable to my rear suspension. It's a lot like that of the F-bodies except this one has a lot more weight on it.
kainzien
Nov 10, 2023 11:37 AM
bagged7104SS
Sep 24, 2015 08:42 PM
Cha_Feel_
Sep 23, 2015 09:06 PM
FormulaZR
Sep 14, 2015 05:23 PM
dselby25
Aug 24, 2015 07:26 PM
