Guys with milled heads get in here
Old Oct 11, 2007 | 10:47 AM
99/5.3w/hips's Avatar
Smile Guys with milled heads get in here
Those with milled heads on a 5.3 what length pushrods are you guys running and how much milling did you have done?
Old Oct 11, 2007 | 12:05 PM
tdrumm's Avatar
.045 mill and 7.35" pushrods.
Old Oct 11, 2007 | 03:15 PM
Silverad04's Avatar
I was told that with the 220/220 cam raising the comprestion ratio to 10 to 1 by milling .030 would help me see beter gains. I could still run on pump gas right? what pushrod should I use if I milled them .030?
Old Oct 14, 2007 | 04:43 PM
southern_chevy's Avatar
anyone for sure how much you have to mill the 5.3l heads for a 10 to 1 ratio?
Old Oct 14, 2007 | 04:52 PM
1TRUESS's Avatar
5.3L .030 & 228R with 7.350
Old Oct 14, 2007 | 04:56 PM
v8
17,16,15,14,13,12,11 Drvr
well generally speaking, if you have a cam and are using 7.425 push rods, and then you mill the heads .25 then stock push rods could be used, if stock cam then minus the length that you mill the heads. hope this helps and if i'm wrong then someone will correct me I hope ahaaha.
Old Oct 14, 2007 | 05:42 PM
kw05silverado's Avatar
^ do u honestly have a tornado?
Old Oct 14, 2007 | 07:31 PM
v8
yes sir I do.
Old Oct 14, 2007 | 07:32 PM
v8
I guess I should say my times 12.51@105.52 all motor baby 5.3 any other questions?
Old Oct 14, 2007 | 07:40 PM
I used to have .030 milled with a 224/228 cam and 7.400 push rods. ran great
