got a oil leak on the 5.7
Old Nov 27, 2005 | 09:05 AM
TURBHOE's Avatar
Default got a oil leak on the 5.7
ok so where are some spots to look for oil leaks in a motor that was torn down cleaned and put back together??
Old Nov 27, 2005 | 10:19 AM
TURBHOE's Avatar
seems to be while sitting still
Old Nov 27, 2005 | 11:01 AM
budhayes3's Avatar
PT's Slowest Truck
Could be alot of different spots...where's the oil coming from, front or rear of the engine, rt or left side? Could be front or rear cover, front or rear crank seal, oil pan gasket, valve cover gaskets, oil pressure sender, oil filter, etc...
Old Nov 27, 2005 | 01:35 PM
litreddevil's Avatar
Banned
THAT SUMS IT UP
Old Nov 27, 2005 | 02:02 PM
treyZ28's Avatar
always start from the top.
oil flows down, not up. a common mistake is to see oil coming from somwhere like an oil pan and assume it is an oil pan gasket. the oil can be dripping from the intake, down the block and cling in the gap between the pan and block.
start up.
Old Nov 27, 2005 | 02:09 PM
budhayes3's Avatar
PT's Slowest Truck
start up.
Thank god for gravity
Old Nov 27, 2005 | 02:14 PM
99Silver6.0's Avatar
Gotta take extreme care when tightening the front and rear covers. And the oil pan. Front main seal can be problematic. Did you have the rear cover off?? That seal is a bitch and a half to get over the crank. Like mentioned before, see where its coming from. Buy a can of brake cleaner and start spraying places clean. Start peeking to see where its oozing from.
Old Nov 27, 2005 | 05:04 PM
TURBHOE's Avatar
It A Rear Crank Seal.. How Can I Install A New One Without The "gm Tool"? The Old One Is Ripped..
Old Nov 27, 2005 | 05:43 PM
It is very very hard. You just have to use a feeler gauge and weasel it on. Do not oil it either!!!! Its best to get a helper honestly. Take your time, each of you just work the seal with feeler gauges and push it over the crank easily. Take your time, youll get it.
Old Nov 27, 2005 | 06:04 PM
TURBHOE's Avatar
thats nice i have about 6-8" to work with betweent the motor and trany will it be easier to just pull the motor the rest of the way out to do this is it that hard?
