Got 'er done (warning 56K killer)
Old Sep 6, 2005 | 08:47 AM
  #21
Scream's Avatar
MOOBIES Moderator
I can't see it being the exhaust...I still have the cast manifolds and y w/ cats on my LS1 and it pulls like a raped ape up top. I have the TR 224. I would think it's something other than the exhaust holding you back.
Did you put springs in w/ the cam? Maybe you're getting valve float up top? I'm wondering if it isn't a valvetrain issue somehow...
  #22
Scream's Avatar
MOOBIES Moderator
And, I'm still running on the stock 4.8 tune for the most part (all I did was bump the rev limiter and shift points up IIRC.)
Old Sep 6, 2005 | 10:21 AM
  #23
Zick's Avatar
Yup put in CC 918 springs. Weird, maybe it is just the tune. Guess I'll find out this Friday after the dyno tune.
Old Sep 6, 2005 | 10:24 AM
  #24
Zick's Avatar
Any chance a crank relearn would be causing this? I was just reading an old thread about it and problems it causes. Right now I keep getting a P0300 misfire detected code, which I assume is from the cam almost killing the engine at low rpms. Also I used the cam & crank sensor from the LS1, instead of swapping the ones from the 5.3.
Are the sensors possible different?
Old Sep 6, 2005 | 10:32 AM
  #25
Scream's Avatar
MOOBIES Moderator
I don't know. I used all of the truck sensors on my swap. If you have no tune at all, it might feel sluggish b/c it's shifting so early. You'll need to run it up to 6400-6500 or so to really feel that cam.
Best of luck w/ the tune. Post up your b/f and after #'s.
Old Sep 6, 2005 | 10:39 AM
  #26
Zick's Avatar
Maybe I'll try swapping the sensors tonight.
Right now I'm shifting at about 6K. I'll get the numbers posted up after I get back.
Old Sep 6, 2005 | 11:49 AM
  #27
BigBlockChev572's Avatar
Originally Posted by Zick
Yeah, you can barely tell its cammed. I've got a Dynomax Ultra Flo 3" in/ dual 3" out waiting to put on. That sould really liven it up.
Their ya go, or be like me and unbolt the exhaust before the muffler and ride. Keep us updated!
Philip S.
Old Sep 7, 2005 | 11:08 AM
  #28
Zick's Avatar
Well I did the crank relearn yesterday and modified the Main VE table. I blended the 5.3 and LS1 tables together, since I'm kind of running a hybrid. On the way to work today it drove much better, had a lot more high end than before.
So I can't say if it was the relearn or VE table that did it for sure since I did them at the same time.
But either way I'm happier with it. Can't wait till Friday.
ClintBeastwood
11
Sep 13, 2015 11:49 PM
turbo truck
Sep 2, 2015 09:58 PM
spiritfish
Aug 23, 2015 09:58 PM
smokeshow
Aug 23, 2015 08:23 PM
