GoodYear Gatorback belt
Old Nov 6, 2010 | 09:29 PM
trever1t's Avatar
2nd fastest 5.3 ECSB
Default GoodYear Gatorback belt
Finally replaced my saggy 109" belt and went with the 108" Gatorback. $41 out the door at a locally owned auto-parts store.
Swapped in some M1 -5-30 and some new Rain-X brand wipers anticpating tomorrow's rainstorm.
Drove 3 hours and damn if my truck isn't running sa weeeet! I don't know if the belt is making any difference or if it's just liking the attention I gave her today but it was a blast to drive.
I know Gatorbacks aren't new or anything, just I never tried one before. They stretch any worse than the others?
Old Nov 6, 2010 | 09:36 PM
sureshot's Avatar
It must be the new wipers! I hope you have luck with the gatorback. I shredded one in no time. I bought a Gates after that, and I've had good luck with it so far.
Old Nov 6, 2010 | 09:44 PM
mhotrodscooter's Avatar
I've had bad luck to with the gator back.. But it's been about 6 years ago.. Maybe they changed the design since then. Good luck..
03 True Fire's Avatar
i worked at autozone for a little over a year before i moved to san marcos, and i had quite a few customers return the gatorbacks because at high speeds the cross ridge design would walk right off the pulleys.. didnt happen to all of the customers but quite a few just to give you a heads up
Old Nov 6, 2010 | 09:46 PM
trever1t's Avatar
wonderful
Well I guess I'll keep the spare stretched belt and the 1/2" drive in the truck.
Old Nov 6, 2010 | 09:55 PM
it might hold up you never know.. i couldnt really give anyone an honest answer when customers would ask if it was worth it.. but some people walk away happy with it.. id be safe and keep a spare belt as well!
Old Nov 6, 2010 | 11:06 PM
1Bear's Avatar
I don’t think they are too appealing looking, but you may get some benefit running one of green Gates HD belts. If you never have to open the hood, I don’t guess it really matters whether the thing is purple, chartreuse or whatever color they wanted to make the thing. Gates does have a racing line of belts and hoses that at least has the cool looking blue outer, but while they list fitments for a lot of stock applications, such as a Vette or whatever, I haven’t seen at least where you can just pick the length you need. You very well may be able to get one in the length you need, I just haven’t found where they are listed to do so. Hell, if Tony Schumacher can get a damn belt from them, you should be able to get a little serpentine belt..........LOL
Old Nov 7, 2010 | 12:47 AM
Mrgoodwrench3's Avatar
I have found that they are junk. Stick with a fully grooved GM / Delco belt.
Old Nov 7, 2010 | 01:53 AM
meangreenburban's Avatar
I've had good luck with my Gatorback on my 350, and it runs up to 5600 RPM on a WOT shift. Keep a spare belt and 3/8 drive either way in mine, its just good sense.
Old Nov 7, 2010 | 05:36 AM
TIM Z's Avatar
11 sec. Truck Mod
Maybe shes running better cuz she has a tighter belt, or its just in our heads that after attention they run better LOL.
I could use a hair shorter belt too, but been have great luck with Dayco poly cog.
