good cam choice?
Old Apr 22, 2006 | 07:08 PM
getchusum99's Avatar
Default good cam choice?
it wont be for another moenth or two but was wonderin what would be a good cam choice for my truck, i want something with a noticeable lope in it. i already have an 02 ls6 cam but havnt installed it yet.but i was thinking of getting something with a lil more low end and more umphh. any idea's ,spec's? oh an sooner or later i will be getting longtubes. and i am in the process of hopefully getting a tb stall in a few days.
Old Apr 23, 2006 | 01:50 PM
thanks for all the input guys
Old Apr 23, 2006 | 01:53 PM
mason110's Avatar
Well what size motor you have? Need more info on your truck
Old Apr 23, 2006 | 02:02 PM
trever1t's Avatar
2nd fastest 5.3 ECSB
Yeah, more data required.
I think this is the most common topic of these forums. I asked the same questions not too long ago. Do a search, check the sponsers web sites, PM someone who's setup is similar to yours.
Engine size, mods, and how you want to drive will determine the correct range of cam for your truck.
Old Apr 23, 2006 | 02:03 PM
bluecajun5.3's Avatar
11 Second Truck Club
how bout the 01 zo6 cam instead. it has a lower duration to help you out on the bottom end.
Old Apr 23, 2006 | 02:15 PM
well i have a 5.3, with a volant cia, cats gutted with a single 3inch bullet, 3.73's front and rear with lockers.built tranny,and am getting a tb stall in a few days , and i have a superchips but am selling it and getting a wait4me , then after i install my cam get it custom tuned by futral motorsports, locally. and sooner or later some pacesetter long tubes. i tow quite frequently and this is my daily driver i also have 203k miles on it , but still runs like a top. i just want something with somewhat of a noticeable lope and performs well all around. the reason i asked about the 02 ls6 cam is cuz i already have one with ls6 springs, a freind with a fbody gave to me, at the shop i work at .waiting to be installed when i do my waterpump and timing chain.also do you guys think that a cam would premature my engine life at these high miles? and i was joking on the second post i made, i know yall get these kinds of post alot, i was just bored so i figured what the hell . this morning ive been looking at the cam thread page and learned a few things. i was thinkin about the comp cams 212/218????
Old Apr 23, 2006 | 02:30 PM
mason110's Avatar
If I were you i would go with something around a 222/222 .561 .561 112 lsa. It all depends on what your looking for. However no need to go higher than a 224/224 in a 5.3. No it wont premature your motor at all just replace springs to acomatate your lift. Replace your timing chain ,and while your at it prolly not a bad idea to replace your oil pump while your in that area.
Replace your gears also with the chain.
Could replace your push rods also.
ARC
57
Feb 21, 2022 10:54 AM
OHsixLS3
Dec 27, 2016 09:30 AM
Cm_gmt800
Aug 3, 2015 09:13 PM
elpyro89
Jul 28, 2015 05:51 PM
steves86ta
Jul 28, 2015 10:21 AM
