Going to the track soon, got a few ?'s
Old Aug 18, 2005 | 04:34 PM
RSTSilverado's Avatar
Default Going to the track soon, got a few ?'s
I have a 05 Regency RST Silverado (Regular Cab Short Bed, A4) with the 5.3L in it and I'm gonna be heading out to the local 1/8th strip in a few days and i was wondering what you think i might run. Mods are JBA shorties, Corsa Exhaust, True Flow Intake(all came stock on RST) and i added a PCMFORLESS 89 octane tune. A couple of my friends are going out there too, they drive a slightly modded dakota r/t, a lt1 trans am, and a older z28. Mods are in sig, im hoping for a low 9 which is in the 14's at the 1/4th. Do you think that's possible? Also the truck only has 1500 miles on it, should i let it break in more before i take it out there? Will the motor breaking in make my times any faster? Thanks
Brett
Old Aug 18, 2005 | 04:37 PM
bluecajun5.3's Avatar
11 Second Truck Club
i talked to a guy at the track who had one. he had came check out my truck in the pits. said his ran 15.10's, i can't remember what the speed was.
Old Aug 18, 2005 | 04:47 PM
Im assuming that's without a tune so hopefully i would be good for 14's in the quarter
Old Aug 18, 2005 | 08:31 PM
v8
17,16,15,14,13,12,11 Drvr
what part of tx you from? and with the heat as it is you might be a 14.8-9 truck.
Old Aug 18, 2005 | 09:34 PM
DFW area, and i forgot to ask... bluecajun.. was that rst a 4.8? Almost all of them are 4.8's but i got lucky and got the 5.3 so maybe i will run better than that 15.10 especially with the tune but yeah heat is a major factor here.
Old Aug 18, 2005 | 10:22 PM
no, he said it was a 5.3. hopefully that tune will wake yours up and get in to the 14's... good luck
Old Aug 19, 2005 | 12:20 AM
jerome's Avatar
mid to high 15's. i dunno what that is in the 1/8th
Old Aug 19, 2005 | 09:53 AM
00stepsyde's Avatar
9.5 10.00 Should be somewhere in that range. The best I have ran is 9.86.
Old Aug 21, 2005 | 10:32 PM
Do you think taking off the spare tire will make any difference?
Also if i swapped out the rear 20's for some stock 16's for the night would i run better? Thanks
Old Aug 22, 2005 | 08:40 AM
swapping the 20's for 16's would definately make a difference i think guys have seen about .3-.4 tenths of a second difference from that.
