Going with E fans what do I need to do?
Old Dec 11, 2010 | 06:28 PM
onebad03's Avatar
i thought the SSS had a 34" radiator already? if so i would get the 05+ efans and harness.
Old Dec 11, 2010 | 09:38 PM
Atomic's Avatar
I have a gauge for that
You need a 34" radiator to fit the 05 fans, basically you need the rad and fans together for anything after 05. Or its fine to have the 34" rad and use the ls1 fans...
Old Dec 13, 2010 | 12:02 PM
Blucreek's Avatar
I run Flex a Lite "Monster" fans($400+)with a Nelson harness controlled with HPT.
Old Dec 13, 2010 | 01:11 PM
baSICK5.0's Avatar
I have fans from a Z. Easily controlled with a little relayed temp switch you can buy from most parts stores. I have $90 in the fans, $35 in the switch. Works awesome, comes on when temps require and always with A/C on. Simple and cheap
Old Dec 26, 2010 | 10:50 PM
thelostartof's Avatar
For what its worth, I just did an Efan swap on my 2002 Sierra 5.3L. $40 Junkyard Volvo Elec fan with shroud and stock relay. $15 adjustable thermostat from parts stores and Efan swap is done. Looks clean and was simple as hell to wire up.
I know the fan is more than enough to cool the stock truck as it works just fine on my 330whp Volvo (4cyl turbo) and nevermind the fact that the volvo rad is thicker and has more internal volume than the stock truck rad so I see no reason why the single fan would not work.
Old Jan 10, 2011 | 06:30 PM
oldred95's Avatar
Does anyone know what the stock fan settings are for an 05 truck with the 34 inch dual fans? Looking for low speed (both fans in series) on temp and off temp, high speed (both fans in parallel) on temp and off temp, A/C high pressure on value, A/C high pressure off value, and both fans off after X mph value. Thanks.
Nevermind found a screen shot from another thread finally.
https://www.performancetrucks.net/fo...62&postcount=4
Old Jan 10, 2011 | 11:38 PM
262_NBS's Avatar
mine seem to run one fan on low speed for driving around town and 2 on low with the air on. I've only seen both fans on high when I disconnected the temp sensor.
CD82
Oct 23, 2015 07:32 AM
Wrecker 426
Sep 30, 2015 09:39 PM
old motorhead
Sep 29, 2015 08:22 PM
97gmc
22
Sep 8, 2015 10:56 PM
Alvin@PCMofNC
Sep 3, 2015 06:38 AM
