GMPP LSX block builds...
Old Jan 15, 2007 | 07:52 PM
CHEVRACER83's Avatar
fueling for now is a custom tune z06 computer... and as time goes on... i have alot of experience with motec management systems... and taht will probably be the control unit i will go with.
i may go 2 step injection just for the bragging rights...
Old Jan 15, 2007 | 07:54 PM
nightrunner's Avatar
Mr. Obvious
Originally Posted by CHEVRACER83
well i will keep you guys updated as builds come and go.... and we'll see what will deliver and what is worthless...
were using stock assembled l92 heads first.... i have seen these things deliver amazing numbers on some ls2s i have built.... were putting this in a new z06... anyone need a "very well" broken in LS7??? (just kidding) the ls7 already has a good home.... in a colorado...
WTH, do work in the toys-r-us section of GM or something damn!
Old Jan 15, 2007 | 07:57 PM
ZR1 DREAMING's Avatar
Do you have access to 6 bolt per cylinder L92 heads? And what CR are you shooting for? Will this be a pump gas engine?
Old Jan 15, 2007 | 08:03 PM
for those of you that dont know... yes i work for GM... I work for their R&d center in southern california....
I design most of the one off parts, and concepts you see in auto shows...
I also design components for stock vehicles such as the engine cover for the denali, and the engine cover for the concept camaro.
so basically yes i do work in the theoretical Toys R us of GM...
I also worked on the recent Hot rod car where we swapped the LS7 into a solstice.
This is just a test to prove the durability of the LSx block and platform, and to prove the legolike structure of LSx components.
I just wish i fit in the test vehicle.
Like i said... If you have any suggestions... I have a pretty big budget.... and want to see what delivers.... you guys tell me and ill see what i can put together.
HERE IS THE TEST VEHICLE
Old Jan 15, 2007 | 08:05 PM
sorry for crappy pic quality... just went and took pics right now... with my wonderful "POS" sprint camera phone
compression ratios will go from 8.5 to 12:1
im trying to see what i can get away with on pump gas.... forced induction, and squeeze will definitely be in the picture after i have exhausted every route of n/a
EDIT: I have access to whatever you want...
Or whateevr i need..... If i have to have it made, machined, or fabricated it is considered "in the budget"
GM wants us to have a LS powered colorado at a car show as soon as possible....
and they want a LSx test vehicle asap.... So basically I get whatever I want.... and get to beat the hell outta it...
Old Jan 15, 2007 | 08:06 PM
Mr. Obvious
i knew you worked for GM just didnt know what dpt.
sounds like a fun job
Old Jan 15, 2007 | 08:09 PM
it is a great job..... I love it.
BTW edited above post...
Not to mention life contract doesnt hurt either...
Old Jan 16, 2007 | 05:27 AM
tdrumm's Avatar
I've been toying with making something that looks and sounds almost stock.
LSx block
4.250 bore, 4.00 stroke = 454 cu in
Ported L92s
L92 truck intake - Peope on tech say that this thing is actually a very good intake.
Target CR 11.0-11.5
With that much displacement it should allow for a decent size cam, yet still idle fairly smooth.
Old Jan 16, 2007 | 11:42 AM
Thats Not A Bad Sounding Combination.... Depending On Cam Could Be Very Driveable Too...
If You Tune It With A Leane Cruise You Could Even Get Decent Mpg
Old Jan 16, 2007 | 01:31 PM
SS_bnoon_SS's Avatar
Dang, big cubes, L92 heads, unlimited budget. Yes sir, that's my version of the American dream right there...
Make mine a 454 SS to revive the early 90's sport truck attempt that GM made. Fit a 230's duration cam at .625 lift with displacement on demand and lean cruise with a 6L80E.
Can you hook a brother up? My SS could be available if you want a truck show car... I'll walk to work for the next year if the truck has to stay in the shop that long... heck, I should probably be walking to work anyway since it's so close...
