GMPP LSX block builds...
fueling for now is a custom tune z06 computer... and as time goes on... i have alot of experience with motec management systems... and taht will probably be the control unit i will go with.
i may go 2 step injection just for the bragging rights...
Originally Posted by CHEVRACER83
well i will keep you guys updated as builds come and go.... and we'll see what will deliver and what is worthless...
were using stock assembled l92 heads first.... i have seen these things deliver amazing numbers on some ls2s i have built.... were putting this in a new z06...
anyone need a "very well" broken in LS7??? (just kidding) the ls7 already has a good home.... in a colorado...
WTH, do work in the toys-r-us section of GM or something damn!
for those of you that dont know... yes i work for GM... I work for their R&d center in southern california....
I design most of the one off parts, and concepts you see in auto shows...
I also design components for stock vehicles such as the engine cover for the denali, and the engine cover for the concept camaro.
so basically yes i do work in the theoretical Toys R us of GM...
I also worked on the recent Hot rod car where we swapped the LS7 into a solstice.
This is just a test to prove the durability of the LSx block and platform, and to prove the legolike structure of LSx components.
I just wish i fit in the test vehicle.
Like i said... If you have any suggestions... I have a pretty big budget.... and want to see what delivers.... you guys tell me and ill see what i can put together.
HERE IS THE TEST VEHICLE
sorry for crappy pic quality... just went and took pics right now... with my wonderful "POS" sprint camera phone
compression ratios will go from 8.5 to 12:1
im trying to see what i can get away with on pump gas.... forced induction, and squeeze will definitely be in the picture after i have exhausted every route of n/a
EDIT: I have access to whatever you want...
Or whateevr i need..... If i have to have it made, machined, or fabricated it is considered "in the budget"
GM wants us to have a LS powered colorado at a car show as soon as possible....
and they want a LSx test vehicle asap.... So basically I get whatever I want.... and get to beat the hell outta it...
i knew you worked for GM just didnt know what dpt.
sounds like a fun job
it is a great job..... I love it.
BTW edited above post...
Not to mention life contract doesnt hurt either...
I've been toying with making something that looks and sounds almost stock.
LSx block
4.250 bore, 4.00 stroke = 454 cu in
Ported L92s
L92 truck intake - Peope on tech say that this thing is actually a very good intake.
Target CR 11.0-11.5
With that much displacement it should allow for a decent size cam, yet still idle fairly smooth.
LSx block
Ported L92s
Target CR 11.0-11.5
Dang, big cubes, L92 heads, unlimited budget. Yes sir, that's my version of the American dream right there...
Make mine a 454 SS to revive the early 90's sport truck attempt that GM made. Fit a 230's duration cam at .625 lift with displacement on demand and lean cruise with a 6L80E.
Can you hook a brother up? My SS could be available if you want a truck show car... I'll walk to work for the next year if the truck has to stay in the shop that long... heck, I should probably be walking to work anyway since it's so close...
