getting a drain on my batt
Old Mar 18, 2005 | 07:01 PM
goshawk23's Avatar
Truck addict
Default getting a drain on my batt
tell me some places to look for possible culprits to a power source draining my battery. for the past few months i have noticed that if i don't drive my truck for a few days, the battery is almost dead. i have had to jump it off several times.
i do have a small amp but it has been in the truck since day one and never caused any problems before. along with that, i have sirius sat radio and i have the box that deciphers what the ant brings in. it needs power. but again, been in the truck for a long time and never a problem.
i thought the little red box was supposed to keep us from draining the bat. it has worked for me before when i left the hood up and the light was on.
Old Mar 19, 2005 | 06:36 AM
WaitinToDrag's Avatar
im in the same boat. on another forum, someone told me it had somrthing to do with my optima yellow top. something about a dry cell battery? and they recommended an aftermarket gel battery like a Stinger Audio battery.
But i didnt research too much more into it bc i fried my 5.3....and its just sittin in my driveway awaiting the 6.0
Old Mar 19, 2005 | 06:53 AM
L82gofast's Avatar
How old is your batt? The stock delco ones seem to either leak at the posts or loose surface charge like that after a couple years.
Old Mar 19, 2005 | 08:48 AM
LowBlack99's Avatar
They have a dealer update for battery rundown but if you batt is a couple years old just replace it. As far as optima batt causing problems they probably just trying to sell you something. I have had good success with the napa gel batterys just like optima and I believe made by same company just a different label with a longer warranty.
Old Mar 19, 2005 | 03:26 PM
goshawk23's Avatar
Truck addict
well my batt is two years old give or take. it's a optima red top. i'll have to investigate some more into red tops.
Old Mar 19, 2005 | 03:27 PM
goshawk23's Avatar
Truck addict
lowblack99, welcome to the board. just noticed this was your first post.
Old Mar 20, 2005 | 12:56 PM
budhayes3's Avatar
PT's Slowest Truck
If you put an ammeter in series with the negative battery cable, you shouldn't see more than a 50 milliamp draw. (with some aftermarket components you may see 55 or so) If you have an excessive draw, you can start pulling fuses one at a time until the draw goes down to normal...when it does you have found the circuit that's causing the drain. Then it's just a matter of disconnecting components on that circuit until you find the culprit.
Old Mar 20, 2005 | 05:08 PM
LowBlack99's Avatar
___
thanks_______________
Old Mar 20, 2005 | 05:13 PM
Default Listen Up!!
Listen up to budhayes3, that is by far the easyest way to diag. a draw problem. G/L
lxcoupe
Sep 25, 2015 12:36 PM
726.0chevelle
Sep 12, 2015 09:24 AM
CategoryX
Aug 30, 2015 01:34 PM
hartinclay
Aug 3, 2015 07:03 PM
