Gen 3 to 4 swap. What Oil Pressure Sensor?
Old Mar 16, 2023 | 08:32 AM
shakenfake's Avatar
Shlumpt
5 Year Member
I have seen a few failures on LS1Tech with it. Just adds in another complication and failure point when you could spend $100 and do it properly with the correct reluctor wheel. Just my opinion
Old Mar 16, 2023 | 08:37 AM
strutaeng's Avatar
5 Year Member
Ah, ok. Yeah, that makes sense.
Old Mar 16, 2023 | 08:38 AM
shakenfake's Avatar
Shlumpt
5 Year Member
Oh my god I'm turning into a cranky old man....
Old Mar 16, 2023 | 08:41 AM
strutaeng's Avatar
5 Year Member
Old Mar 16, 2023 | 09:14 AM
Zac28's Avatar
Thanks for all the help guys!
I should have everything else needed, or at least have it ordered. So far I have gen 4 timing cover, valley cover, cam/crank sensor extensions and gaskets/seals at home. Still waiting on cam sensor (back ordered), but I may have to get a cam timing gear too. I cant remember whats in there now but I know its either for 1x or 4x. A little back story. Back in November I put a junkyard LQ9 in it with 799's and a small cam. After 3 months of messing with it I couldnt get rid of loud passenger side valve train noise and a slight knock so I decided to get a short block built. Only problem with that is no one has gen 3 blocks laying around so I had to go with gen 4. Once the swap is done I'll get the LQ9 checked out and see about building or selling it.
Gen 4 motor is being built with 24x reluctor so I'm good there. I also heard a few people had issues with the box as well. Some the box just crapped out and another had issues from water intrusion. For me it was enough that I'm willing to wait 6 weeks to have a motor built with a 24x vs getting one on the shelf ready to go with a 58x.
Old Mar 16, 2023 | 11:22 AM
RDF1's Avatar
DuNnO
5 Year Member
Yea those 58x to 24x converter boxes will leave you stranded.. Ive thrown quite a few away. Running a Holley ECU was the easiest way to fix it.
shakenfake's Avatar
Shlumpt
5 Year Member
I have a boner for factory only.
Old Mar 16, 2023 | 11:45 AM
RDF1's Avatar
DuNnO
5 Year Member
When you figure out what the possibilities are with a Holley Dominator It will change your mind.
Old Mar 16, 2023 | 01:43 PM
shakenfake's Avatar
Shlumpt
5 Year Member
Oh I know, I am going Holley in a Pontiac Big Block build.
I just want my factory **** to work like factory. Namely my gauges. I hate electronic gauges.
Old Mar 16, 2023 | 09:03 PM
RDF1's Avatar
DuNnO
5 Year Member
Stock gauges still work fine in the turbo trucks i build for folks. It just uses the stock PCM to send the signals to cluster. Holley just controls the important stuff haha
Lane_Hesser
Jul 14, 2018 12:05 PM
BBPanel
Nov 1, 2017 01:11 PM
Jake75
Jan 24, 2016 01:18 PM
Cammed4ever
Oct 30, 2013 08:44 AM
Quicklynx
Apr 1, 2012 11:29 PM
