Gear install kits
Old Jan 14, 2004 | 08:12 PM
TwoFast's Avatar
Default Gear install kits
Do you really need one, because if your just swiching out the gears why would I need all of the other stuff that comes in an install kit? Just wondering.
What comes with the install kits, bearings, gaskets, etc....????????
Old Jan 14, 2004 | 09:04 PM
FILE's Avatar
You do need an install kit when you are swaping gears. Normally an install kit comes with the following: pinion bearings, carrier bearings, pinion nut, pinion shims,pinion seal, carrier shims, ring gear bolts, crush sleeve, gaskets & checking compound. Since you are using the same carrier you will not need any carrier bearings.
Old Jan 15, 2004 | 08:00 AM
Seeing Red Again's Avatar
Its a good idea on any gear swap to go ahead and rebuild the rear (especially on high mileage rears), bearings and all. About the only thing I reuse during a gear swap is some of the shims, though you still need extra shims to set backlash,etc. New bearings are cheap insurance for an expensive rear.
Choda
Jan 22, 2026 02:03 PM
LCHEE
Oct 24, 2020 04:10 PM
1slwgto
Aug 16, 2015 06:40 PM
iregret
Jul 27, 2015 10:31 PM
FlowmasterMufflers
Jul 17, 2015 03:26 PM
