gas pedal sticks
Old Dec 28, 2004 | 11:03 PM
Default gas pedal sticks
i have a problem i need help with , my 99 z71 gas pedal stays stuck when i am going to press it i need to press it hard so i can give it gas some say i need to clean throtle body or something , can some one show me how i can fix this problem? im not much of amechanic and i feel like acomplishing something on mechanics thanks guys
Old Dec 28, 2004 | 11:57 PM
jcfreak's Avatar
Get some carb cleaner and pull off the intake for the tb. Open the trottle and clean all the black carbon deposits off around the trottle blade. It should spray right off. Thats whats causing it to stick.
Old Dec 29, 2004 | 12:29 AM
Green Thunder's Avatar
Increased Accelerator Pedal Effort from Idle Position (Clean Throttle Body and Adjust Blade) #04-06-04-079 - (Oct 25, 2004)
Table 1: TPS Voltage Chart
Increased Accelerator Pedal Effort From Idle Position (Clean Throttle Body and Adjust Blade)
1999-2002 Chevrolet Silverado
2000-2002 Chevrolet Suburban, Tahoe
2003-2004 Chevrolet Express
1999-2002 GMC Sierra
2000-2002 GMC Yukon, Yukon XL
2003-2004 GMC Savana
with 6.0L Engine (VIN U - RPO LQ4)
Condition
Some customers may comment on a higher than expected accelerator pedal effort from the idle position.
Cause
Condition may be caused by deposits in the throttle body bore and on the throttle plate.
Correction
Important: This procedure only applies to cable actuated throttle bodies on the models listed above. This procedure should not be performed on electronically controlled throttle bodies or on any vehicle or engine that is not listed above in the Models section.
Verify that the cause for this condition is not a damaged or binding throttle cable.
Remove the air intake duct. Refer to Air Cleaner Duct Replacement.
Inspect the vehicle for installation of a fixed orifice PCV valve, refer to Corporate Service Bulletin 01-06-01-029B for PCV valve identification. Vehicles completing this throttle body procedure must use a Fixed Orifice PCV Valve, P/N 12572717.
Clean throttle body bore and throttle valve plate of carbon using a shop rag and an appropriate cleaner. Refer to Engine Controls Repair Procedures - Throttle Body Cleaning Procedure.
Select the correct plug for the size of the air bypass hole in the throttle body being serviced. Use a 5/32-inch drill bit to determine which plug to use. • Vehicles built before introduction of the Fixed Orifice PCV Valve will have a 4.0 mm (.157") air bypass hole in the throttle plate. The 5/32-inch drill bit is smaller than the air bypass hole in these throttle bodies and can be inserted into the bypass hole. To reduce the air bypass hole in these vehicles requires the gray plug, P/N 12583703.
• Vehicles built after introduction of the Fixed Orifice PCV Valve will have a 3.65 mm (.144") air bypass hole in the throttle plate. The 5/32-inch drill bit is larger than the air bypass hole in these throttle bodies and cannot be inserted into the bypass hole. To reduce the air bypass hole in these vehicles requires the blue plug, P/N 12583704.
Insert the appropriate plug (1) into the air bypass hole in the throttle plate. Insert the "tail" end of the plug through the throttle plate air bypass hole. (Refer to Figure 1)
Open the throttle plate to allow access to the tail end of the plug. Pull the tail section to securely position the plug into the air bypass hole and trim excess material (1) from plug. (Refer to Figure 2)
Turn ignition key to the on position, with engine off.
Use the Tech 2® Scan tool to read initial TPS voltage.
Important: TPS voltage cannot exceed .69 V. If the vehicle has an initial TPS voltage greater than .61 V, replace the Throttle Body Assembly.
Using the Tech 2® Scan tool and a T15 driver to rotate the Minimum Air Rate screw, increase TPS voltage by .08 Volts (refer to TPS Voltage Chart below).
Turn ignition key to the off position. Verify that the accelerator pedal moves freely - Depress the accelerator pedal to the floor and release.
Install the air intake duct. Refer to Air Cleaner Duct Replacement.
Start engine.
Using the Tech 2® scan tool, monitor TPS voltage and verify the TPS voltage is no greater than .69V.
Road Test Vehicle.
TPS Voltage Chart Initial TPS Voltage
TPS Voltage After .08 Volt Increase
.45 V
.53 V
.47 V
.55 V
.49 V
.57 V
.51 V
.59 V
.53 V
.61 V
.55 V
.63 V
.57 V
.65 V
.59 V
.67 V
.61 V
.69 V
If initial TPS voltage is greater than .61 V - Replace Throttle Body Assembly
Parts Information
Part Number
Description
Qty
12583703
Plug, Throttle Plate - Gray
1 as req'd
12583704
Plug, Throttle Plate - Blue
Old Dec 29, 2004 | 12:50 AM
Condition
Cause
Correction
Start engine.
Road Test Vehicle.
.45 V
.53 V
.47 V
.55 V
.49 V
.57 V
.51 V
.59 V
.53 V
.61 V
.55 V
.63 V
.57 V
.65 V
.59 V
.67 V
.61 V
.69 V
Parts Information
Part Number
Description
Qty
12583703
1 as req'd
12583704
wtf ill just stick to what jcfreak said! is that what i should do or what?
Old Dec 29, 2004 | 12:56 AM
That is a GM Bulletin...
Old Dec 29, 2004 | 01:17 AM
no beef here not mad at you
Old Dec 29, 2004 | 08:21 AM
FILE's Avatar
Condition
Cause
Correction
Start engine.
Road Test Vehicle.
.45 V
.53 V
.47 V
.55 V
.49 V
.57 V
.51 V
.59 V
.53 V
.61 V
.55 V
.63 V
.57 V
.65 V
.59 V
.67 V
.61 V
.69 V
Parts Information
Part Number
Description
Qty
12583703
1 as req'd
12583704
Good info.. Thanks.
Old Dec 29, 2004 | 08:48 AM
KeukaZ71's Avatar
i do this every 4-6 months or so. it does the trick. gives me something to do to my truck when i am bored or have no modding to do
Old Dec 29, 2004 | 09:21 AM
Make sure to use throttle plate or throttle body cleaner
Use carb cleaner on carbs.
Doesnt hurt to spray a little on a rag and open the TB and clean both sides of the
plate - if your OCD like me - I take the entire assy off and clean it.
But I'm Monk's twin
Old Dec 29, 2004 | 10:10 AM
user 108208932024's Avatar
Banned
Same thing happened to mine so I just took the whole EGR system out, more room up front an no more stick.
