G80 work on '97 1500 series truck?
Old Jan 17, 2004 | 05:52 AM
L-EATER's Avatar
11 Second Truck Club
Hey 67SS-Can you post that bearing number? I am quite interested in storing that in my files 'cause I have attempted 2 of these swaps and had to abort both times because I couldn't find the proper bearings. Thanks.
Old Jan 17, 2004 | 04:44 PM
67SS509's Avatar
10 Second Truck Club
Finally remembered to bring the part no's home. To install a G80 from a 1998 & up truck with the 8.6 rear into a 1997 or down you will need the following bearings. Note...because the bearings are a smaller diameter they also are not as wide and your shimming will have to be thicker accordingly.
bearing=LM-102949 race=LM102910
To use the Eaton posi #19559-010 in a 1998 & up truck with 8.6 rear you need the following bearings. Existing shims usely will work.
bearing=LM-603049 race=LM-603012
Hope this helps.......
Old Jan 17, 2004 | 09:01 PM
L-EATER's Avatar
Thanks a bunch-I am going to write those numbers down somewhere so I will have them for future reference!
SLOPONY
20
Oct 18, 2016 06:05 AM
black6spdz
Jul 16, 2015 01:32 AM
FlowmasterMufflers
Jul 9, 2015 12:00 PM
FlowmasterMufflers
Jul 9, 2015 11:35 AM
mrgrim
Jul 8, 2015 08:12 AM
