G80 work on '97 1500 series truck?
Hey 67SS-Can you post that bearing number? I am quite interested in storing that in my files 'cause I have attempted 2 of these swaps and had to abort both times because I couldn't find the proper bearings. Thanks.
Finally remembered to bring the part no's home. To install a G80 from a 1998 & up truck with the 8.6 rear into a 1997 or down you will need the following bearings. Note...because the bearings are a smaller diameter they also are not as wide and your shimming will have to be thicker accordingly.
bearing=LM-102949 race=LM102910
To use the Eaton posi #19559-010 in a 1998 & up truck with 8.6 rear you need the following bearings. Existing shims usely will work.
bearing=LM-603049 race=LM-603012
Hope this helps.......
SLOPONY
20
Oct 18, 2016 06:05 AM
FlowmasterMufflers
Jul 9, 2015 12:00 PM
FlowmasterMufflers
Jul 9, 2015 11:35 AM
mrgrim
Jul 8, 2015 08:12 AM
