G80 Rear End Squeaks???
Old Sep 3, 2002 | 01:49 PM
z71tahoe's Avatar
Default G80 Rear End Squeaks???
When I take corners at low speeds it sounds like some kind of belt squeak noise is coming from the rear end? Only in turns- any idea what this is- Could it be the differntial engaging or some sort of ride control??? It happens everytime and is only when turning at low speeds. It is not comming from the front- Dealer says that some sort of "mystery" piece of rubber is hitting somewhere- where do they get some of these people?
Any good dealers in New England.
Thanks for the help.
ben
<small>[ September 04, 2002, 07:55 PM: Message edited by: Ben Tickner ]</small>
Old Sep 4, 2002 | 08:00 PM
z71tahoe's Avatar
Default Re: G80 Rear End Squeaks???
Well still no replys-
Does anyone recommend replacing the G80 locker? I dont know what else could be causing this squeak that only happens in a turn from a stop....
Thanks-
ben
My ATI Tahoe page
Old Sep 4, 2002 | 08:21 PM
L82gofast's Avatar
Ben,
A few suggestions before dropping dime on a new locker. How old are your shocks? They could be doing this.
A locker usually will "clunk" not squeak, but cheap and easy would be to drain the fluid and replace. Remember to put in a bottle of posi additive. That may be all you need.
Mike
Old Sep 4, 2002 | 08:35 PM
parish8's Avatar
single digit dreamer
doesn't the g80 take synthetic and no additive? not sure about this.
Old Sep 4, 2002 | 08:38 PM
AKZ71's Avatar
My dealer recommended I put in the additive with the synthetic. It was not that expensive and I have had no problems with it in there at all.
Old Sep 4, 2002 | 08:39 PM
CashDudeHomie's Avatar
I heard it is actually a posi and not a locker, so I would think it needs the additive but I am not very sure of this. Maybe you have the wrong fluid mixture and that is causing this sound.
Old Sep 4, 2002 | 08:50 PM
The g80 locker takes 75w90 synthetic. I am currently using Lucas syn. The Lucas has a climbing additive in it, so you dont have to add any. its cheap too @ $9.00 a bottle. My rear makes a squeek too, its the bushing in the lowered shackles . try lubing them up.
Old Sep 5, 2002 | 08:02 PM
z71tahoe's Avatar
Thanks for the replies. I tried driving around in circle's from a stop (under 20mph) and it squeaks the entire way around while I give it gas. i am going to try replacing the fluid this weekend- I am almost positive it is not the shocks
(yes i removed them and drove around like an idiot this morning)
My neighbors probably think I installed hydraulics, just what I need now. I am the crazy neighbor that takes a perfectly good brand new truck and makes it ridiculously loud, too fast and bouncy like p diddy music video)
ben-
pjb1972
Sep 17, 2015 02:06 PM
TimDave217
Aug 24, 2015 04:38 PM
vipergtrdj
Aug 6, 2015 10:19 PM
shupe
Aug 5, 2015 06:45 PM
Ketis
Jul 23, 2015 12:37 PM
