Fuel rail ??? guys
Old Sep 15, 2006 | 03:39 PM
Mangled03gmc's Avatar
Baltimore Whore
Question Fuel rail ??? guys
I have a 05 6.0 which has a returnless fuel system, my truck is an 03, thats a return system. My ? is can I take a set of pre 2005 fuel rails and put them on my 05 intake to make it a return system so I can put this damn engine in my turd. Will it work, is there anything i will have to change.. Thanks alot
Old Sep 15, 2006 | 03:46 PM
RoninsDenali's Avatar
As far as i can tell, the [truck] fuel rails are all interchangeable.
Old Sep 15, 2006 | 04:33 PM
1slow01Z71's Avatar
Tin Foil Hat Wearin' Fool
Use your 03 intake they are the same and you dont have to bother swiching the rails.
Old Sep 15, 2006 | 04:53 PM
Baltimore Whore
My 03 intake is in my truck now, the 6.0 is sitting on the stand, when i do the swap I just want to have the **** on there ready to go, I am just being a lazy *** thats why i posted. Thaks JOHN
Old Sep 15, 2006 | 05:14 PM
litreddevil's Avatar
Banned
it is alot harder to put the motor in with the intake on than with out
Old Sep 15, 2006 | 05:22 PM
1slow01Z71's Avatar
Put the motor in with the intake OFF. You will have hell getting the grounds tightened in the back and plugging in the cam sensor and oil pressure sending unit. Trust me. You will see when you go to take the 5.3 out
Old Sep 15, 2006 | 06:18 PM
Tahoe6.0's Avatar
just did a LQ4 swap and i thought the same, take both intakes off its alot easier. The bell housing bolts/ brackets are a bitch even with the intake off. the two grounds and senors are cake to do with intake off. The manifold will take half hour to change, tops!
Old Sep 16, 2006 | 03:18 AM
bluecajun5.3's Avatar
11 Second Truck Club
i think he has a 4.8 in there.
Old Sep 16, 2006 | 11:40 AM
04BlackSilverado's Avatar
Return systems are better for performance, run your 03 intake and fuel setup. A lot easier than trying to swap too.
Old Sep 16, 2006 | 11:58 AM
Baltimore Whore
Yes I do have the lil ole 4.8 and but it should still be the same, if so then I will just use mine once i get the engine out of my truck. Thanks guys once again.. cheers to ya
OHsixLS3
Dec 27, 2016 09:30 AM
Slammed96
Jul 27, 2015 07:22 AM
lxcoupe
Jul 21, 2015 02:12 AM
GMCtrk
Jul 17, 2015 06:39 PM
6.Slow06
Jul 7, 2015 09:19 PM
