Fuel rail ??? guys
I have a 05 6.0 which has a returnless fuel system, my truck is an 03, thats a return system. My ? is can I take a set of pre 2005 fuel rails and put them on my 05 intake to make it a return system so I can put this damn engine in my turd. Will it work, is there anything i will have to change.. Thanks alot
Use your 03 intake they are the same and you dont have to bother swiching the rails.
thats why i posted. Thaks JOHN
Put the motor in with the intake OFF. You will have hell getting the grounds tightened in the back and plugging in the cam sensor and oil pressure sending unit. Trust me. You will see when you go to take the 5.3 out
just did a LQ4 swap and i thought the same, take both intakes off its alot easier. The bell housing bolts/ brackets are a bitch even with the intake off. the two grounds and senors are cake to do with intake off. The manifold will take half hour to change, tops!
Originally Posted by bluecajun5.3
i think he has a 4.8 in there.
lxcoupe
Jul 21, 2015 02:12 AM
GMCtrk
Jul 17, 2015 06:39 PM
