Fuel Pump? Injectors?
Old Apr 10, 2007 | 07:17 AM
trever1t's Avatar
2nd fastest 5.3 ECSB
Default Fuel Pump? Injectors?
Do you think swapping fuel pump or injectors would be wise when I add the demand of N2O to my fuel ststem?
I have the Maggy fuel pump and currently pressure is 65lbs at idle and 58lbs at WOT. Injector duty cycle is at 92% even with the Meth.
I might as well upgrade the fueling system while were in there so what do you suggest?
Old Apr 10, 2007 | 08:25 AM
Quik's Avatar
5 year bitches!
yes and yes, you shouldnt be over 85% duty
Old Apr 10, 2007 | 11:50 AM
thunder550's Avatar
High on diesel fumes
Get some 96lb injectors!! At 8psi on my 408 at 6000 RPM I'm at about 43% IDC
I'm still running the stock in-tank pump with the Walbro inline - although mine is different because it's return-style....haven't started to see any pressure drop yet.
Old Apr 10, 2007 | 12:28 PM
WJ MARK's Avatar
not to thread jack but where are you guys getting your intank Walbro, Part # and how much?
Old Apr 10, 2007 | 12:47 PM
cyazo6's Avatar
trever1 when you find injectors let me know. I've been trying to get a hold of Nelson's Performance. I would like to find 60lb short ones so I don't have to build a spacer for the Radix's fuel rail.
Old Apr 10, 2007 | 12:49 PM
CHEVRACER83's Avatar
YOU SHOULD DO A PUMP JUST TO KEEP UP WITH THE DEMAN..... AND THE STOCKER ISNT GREAT.
THE INJECTORS ALSO BECAUSE YOURS ARE WAY OVERWORKED.... THEY MAY AS WELL BE AN OPEN TUBE.... THEYRE OPEN ALMOST ALL THE TIME
Old Apr 10, 2007 | 12:50 PM
nightrunner's Avatar
Mr. Obvious
id say some 60lb injectors(which require car adapters) should suffice
id go ahead and get a intank if you can, i dont know what there is on the 03-up fuel systems
Old Apr 10, 2007 | 12:57 PM
trever1t's Avatar
I have the Magnuson (radix kit) pump already, but am thinking I'll upgrade anyway. Rick said he has a Bosch 420 pump he can put in the tank by modding the bucket system wtf that means, lol.
I'm not sure on the injectors.
Old Apr 10, 2007 | 02:15 PM
cyazo6's Avatar
Well I bought 6o's from Nelson today along with a snow performance meth kit. Alen was great to deal with!
5.3Okasai
Mar 9, 2022 01:07 PM
05GMC4.8
Aug 7, 2015 09:55 PM
Sexyrado327
Aug 2, 2015 04:08 PM
MS3Z
Jul 30, 2015 06:17 PM
Mossyoakglock
Jul 17, 2015 08:30 AM
