Fuel pressure and boost gauges for Radix application
Old Feb 11, 2005 | 01:37 PM
wkdivr's Avatar
Question Fuel pressure and boost gauges for Radix application
I'm finallizing all my small parts for the Radix install. I plan to connect a fuel pressure gauge sending unit to the schreder valve port on the Radix fuel rail. Is that a good spot? If so, what is the size of the inside thread to adapt to? It looks to be 1/16" npt male. Correct? Also,which port do I connect the boost gauge to? There's two on the driver's side rear, one with a plug, and one with a cap. Are these the ones to see the correct boost numbers? Thanks
Old Feb 11, 2005 | 05:22 PM
wkdivr's Avatar
Question
nobody??
Old Feb 11, 2005 | 09:49 PM
wkdivr's Avatar
Smile
ttttttt
Old Feb 12, 2005 | 09:20 AM
wkdivr's Avatar
is Metco the only solution for a single fitting?
Old Feb 12, 2005 | 09:57 AM
TG02Z71's Avatar
Just posted something similar for my turbo boost gauge, I'll pm you if I get an answer for the boost gauge.
Old Feb 12, 2005 | 10:08 AM
wkdivr's Avatar
Thanks! During a search yesterday, I ran accross someone mentioning something about breaking off a plastic tab on the pass side, and plumbing from there. I'm going to run my boost gauge from a fitting on the Radix intake manifold with a -3 braided line to my gauge pod.
Old Feb 13, 2005 | 06:12 AM
wkdivr's Avatar
ttttttt
Old Feb 13, 2005 | 06:45 AM
KySilverado's Avatar
Either of the ports on drivers side rear will work. I removed the threaded brass plug one and installed the compression fitting that cam with the gauge.
Do a search here on gauge install someone awhile back posted the earls fittings part numbers to connect the sending unit to the schreder valve port. The electric sending uint I installed is long and to fit it has to stand straight up from the rail. Looks like hell. Want to move it to the front of the rails at some point.
Luck!
Old Feb 13, 2005 | 07:24 AM
wkdivr's Avatar
I ordered all kinds of fittings, hose, and adapters from Summit, and Jeg's. My sending unit is rather large, too, I'm going to try to run a braided line off to the side to clean it up. I ordered fittings to tap into that spot on the manifold for the boost gauge, too. I notice in your sig you have the 05 e-fans. do you also have the larger radiator? I'm thinking of doing some sort of e-fan install in the future.
thunder550
Oct 8, 2015 04:53 PM
wrb002
Aug 31, 2015 12:00 PM
Mossyoakglock
Jul 17, 2015 08:30 AM
