flowmaster bad
Old Apr 9, 2007 | 11:54 AM
LS1TRUCKGUY's Avatar
i have a dronemaster because i love the throaty sound. even though it does drone at highway speeds.
Old Apr 9, 2007 | 11:57 AM
Scream's Avatar
MOOBIES Moderator
I love the way my Flowmasters sound.
I don't care if it loses 10hp, I'll run them. I can make that up elsewhere.
Old Apr 9, 2007 | 12:05 PM
bgray's Avatar
TOTM: June 2007
yah...i got 2 40 series...sound badass....
you could gain power from a fagnaflow or another straight through...but then you ahve to listen to a magnaflow...soooo
Old Apr 9, 2007 | 05:49 PM
ReSpAwN DeMoN's Avatar
Awesome!! I really appreciate it fella's..
So I will stick to my 50 series..
another stupid question while we're on the subject.. I have the exhaust dumping right out of the muffler before the rear axle.. does adding additional piping to take the exhaust to the back have any effect on power output? or would that be a waste of money.. opinions?
Old Apr 9, 2007 | 05:58 PM
nightrunner's Avatar
Mr. Obvious
ive heard that it will get rid of rasp and drone on some setups
Old Apr 9, 2007 | 09:48 PM
Originally Posted by ricoc
keep in mind the inside diameter of a staight through. Some staight throughs that have 2.5" pipes are only 1.5" inside. Also on a side note a street bike with 1" exhaust tip can dyno well over 100hp. Flowmaster sometimes rate their stuuf in hp Eg. 2.5"=250hp
That's the biggest load of BS I've ever heard of So how come some 1000+hp cars are running 3" exhaust... I mean seriously. And a 1" exhaust tip on a motorcycle will not make it jump 20+ hp on a dyno... and have you ever even seen the inside of a straight through muffler... obviously not since you think they reduce in size...?
Old Apr 9, 2007 | 09:59 PM
53bowtie's Avatar
i had tru dual 40 series flowmasters and changed to a single aero turbine muffler 3" inlet and 3" outlet and i could actually feel the difference in throttle response although the areo turbine is just a touch quieter at idle it is as loud if not louder in the higher rpm ranges....just my 2 cents worth....by the way i have a 02 single cab with a 5.3L.
Old Apr 10, 2007 | 01:39 AM
ricoc's Avatar
In defence
I should clarify I had a stock ZRX1200 which is known to be roughly 140hp and the pipe outlet was 1.25"
If you look inside a 2.25" glass pack, you'll find the louvers take up space inside that 2.25 and leave you with far less than 2.25 straight through
Currently, my 99 has no cats, stock exhaust manifolds, 2.5" mendrel bent Y, 18x3.5 collector, 3" mendrel to the bumper where I mounted a 50 series deltaflow flowmaster. It still drones and rasps like it should. Performance wise I'm not sure its much more than stock, and I blame the cam for that.
Old Apr 10, 2007 | 01:50 AM
RandomHero's Avatar
I guess it's different stroke for different folks. I absoultely hated my single in dual out flowmaster 40 series. I'm now running a dynomax bullet and couldn't be happier.
RustyD
May 23, 2016 07:04 PM
00loudchevy
Dec 3, 2015 05:54 PM
dsbodley
Nov 14, 2015 09:46 PM
lukn4trbl355
Oct 21, 2015 11:19 PM
Chevy305
Sep 28, 2015 09:21 PM
