Flex-A-Lite Fan Install
Old Jul 21, 2004 | 05:33 PM
therock's Avatar
When my ign hot connection went bad the truck was idling outside a store. When I returned the ac was hot. The fans didn't run either.
Old Jul 22, 2004 | 10:20 AM
adrianmt75's Avatar
So, what did you do to fix it?
New connector, New location? Are you still using the in-line fuse jumper terminal that came with the kit?
After switching the polarity on my fans my AC is not hot anymore. It just shuts off along with the other peripherals I mentioned.
I'd like to tap into that main wire harness coming off of the fuse block.
Thanks,
thunder550
Oct 8, 2015 04:53 PM
mr03silverado
Jul 17, 2015 02:15 PM
